Top mechanism is open and will not close??
#47
Anup, it seems to me that you are in need of the motor of the package tray. Same part that was necesary for me to replace and the cost was $354 at the lexus dealer. Can you send me a photo of the cracked part you have . After working so many hours on the top mechanism I got to know pretty well every part involved. Indeed in order to be able to move the package tray(big center piece ) or the sides triangle shape parts , you have to unplug some cable in each side (kind of a pita, until you get a feel for it, very unaccesible spaces to get to this cable. Anyways, here are some pics of the part that needed replaced. If you have any other questions , just ask... good luck
Previously, when I brought the car to Lexus, they could not trigger a malfunction. TechStream is a must for troubleshooting top issues. Thanks to this forum I was able to pin the root cause.
#49
Congratulations on getting it working! You are right, the system only displays code as it goes through it's process. It does not store them. If the system works "Off & On" it can be very frustrating trying to catch the code.
