Navigation problem
Old Nov 27, 2006 | 02:05 PM
wrfahmy's Avatar
wrfahmy
Default Navigation problem
I own 2002 sc430 and i am trying find the code to allow me to navigate while i am driving?
Old Nov 28, 2006 | 06:18 AM
tfischer's Avatar
tfischer
25 Year Member
Do a search on this forum.
There are many posts regarding the override codes.
Old Nov 28, 2006 | 11:43 AM
paul_k's Avatar
paul_k
Nav Diagnostic override mode Option 1.
Go to the DVD screen (Menu/DVD) and touch the following 3 corners of the screen in this order:
Top Left, Bottom Left, Top Left, Bottom Left, Bottom Right.
This bring up a diagnostic menu screen.
Touch and hold "Override" for about 3 seconds until the square changes color.
Then go "Back."
You can now access all NAV menu items while the car is moving.
Note three things: 1. This setting is lost when you stop the engine, and the setting can only be made while the car is stopped. 2. Don't mess with anything else in that menu -- you can screw up the settings and calibration of the GPS if you are not careful. 3. Messing around with the menus while driving CAN really be distracting and is dangerous (which is why you can't do it --- this override is for testing and diagnostic purposes) -- only use this if you have a passenger who might want to make some settings. In the several years I have known about this, I have seldom found it as helpful as I thought I might. It's nice to know it's there, but frankly, it's not all that big a deal.
Option 2
1. START DIAGNOSTIC MODE
(a) There are 2 methods to start diagnostic mode. Start
the mode by using one of them.
(b) Method 1
(1) Start the engine.
(2) While pressing and holding the "INFO" switch,
operate the light control switch: OFF → Turn ON
→ Turn OFF → Turn ON → Turn OFF → Turn
ON → Turn OFF.
(3) The diagnostic mode starts and the "System
Check Mode" screen will be displayed. Service
inspection starts automatically and the result will
be displayed.
(c) Method 2
(2) Switch to the "Display Check" screen.
(3) From the display quality adjustment screen,
touch the corners of the screen in the following
order: upper left → lower left → upper left →
lower left → upper left → lower left.
(4) The diagnostic mode starts and the "System
be displayed.
2. FINISH DIAGNOSTIC MODE
(a) There are 2 methods to end diagnostic mode. Use
one of them.
(1) Turn the engine switch off.
(2) Press and hold the "DISP" switch for 3 seconds.
Old Nov 28, 2006 | 03:13 PM
JCtx's Avatar
JCtx
ON → Turn OFF.
Did you mean the headlight switch? If so, which of the 3 positions (parking lights, headlights, auto headlights)?
Interesting 2nd method. Does it work on ALL SC430s? Because there're 3 different 'tapping corner' methods for different years. Thanks.
KelaD
Sep 29, 2015 05:20 AM
lex_es
Apr 8, 2008 06:28 PM
Ajw
GX - 1st Gen (2003-2009)
Jun 14, 2006 10:30 PM
IELAWDOG
Apr 25, 2006 07:08 PM
89vette
24
Sep 1, 2005 08:10 AM
