Maybe someone can check this...
Old Feb 25, 2006 | 02:46 AM
powmax's Avatar
powmax
Default Maybe someone can check this...
Hi guys,
please can someone check these values:
we aligned the car to the TEIN specifications, but today the car feels very soft at rear. i have the feeling that something is wrong... the car runs straight ahead, but on cornering i have the feeling that the rear will brakeout (sure it does not, but my ***-meter tolds me so)...
thank you in advanced
marcus
Old Feb 25, 2006 | 07:53 AM
GEE-BEE's Avatar
GEE-BEE
Default Sc430 Tein Cs
Mine felt the same way , i went four clicks out on the rear , 2 on the front
Maybe a dazien sway bar kit is is in order
I hope they start making them for the 06
Old Feb 25, 2006 | 08:00 AM
powmax's Avatar
powmax
DAIZEN arrived this morning at the airport, can't fetch them b4 monday
i adjust both front and rear to the hardest position... makes no difference...
regards
marcus
Old Feb 25, 2006 | 09:39 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Marcus,
car is coming along very well. Congrats!
Did you try softening the front and leaving the rears at the hardest position?
If so , the those new sways will really help out as the rears have three adjustments.
Lee
Old Feb 25, 2006 | 10:39 AM
tonydt1g3r's Avatar
tonydt1g3r
damn marcus your moving quick
Old Feb 25, 2006 | 11:35 AM
powmax's Avatar
powmax
thank you, thank you,
well i phoned my mechanics and told him about the problem, he said maybe the "Visualiner" on which we setup the car is not 100% calibrated, because 3 other cars have the same problem with a soft feeling rear, so it could be that TOE and CAMBER are a way to much off the line and this would lead to my problem... so we have to reset the car next week 2gether with the sways!
i will first trying the stock alignment settings - so hopefully they will good enough...
regards
marcus
Old Feb 25, 2006 | 06:22 PM
bt430's Avatar
bt430
regards
marcus
You may be on the right track here as I've got mine aligned to the stock settings and the coilovers set to the hardest position front and rear. I have the Daizen rear bar set to the stock setting. It corners as well as my M5
Old Feb 27, 2006 | 11:49 AM
powmax's Avatar
powmax
installed the swaybars today... damn wot a difference in handling that mod makes...
nevertheless - on friday we will realign the car to the stock settings...
regards
marcus
Old Feb 27, 2006 | 12:10 PM
rominl's Avatar
rominl
exclusive matchup
wow, that looks very dirty / rusty
Old Feb 27, 2006 | 12:27 PM
powmax's Avatar
powmax
hehe - yes buy a TOYOTA or LEXUS and drive it 3 weeks on wet german streets - and your car will look like this...! but it is just a fine rust film - nothing to worry about...
regards
marcus
islexusred
Suspension and Brakes
13
May 6, 2015 04:09 PM
blacksc4
Nov 19, 2010 10:37 PM
Scott1258
Jul 13, 2007 09:45 PM
