SC430 HEADER INSTALL THREAD w/PICS, DYNO
Old May 6, 2006 | 09:15 AM
  #136
GILLEXUS's Avatar
GILLEXUS
Pearlpower,
Since you've messed w/ the O2 sensors, Do you know if both front O2 sensors (pre-cat) are the same and if both after-cat O2's are the same? I was loking to buy a front O2 sensor in case they had problems when they installed my headers.
Lexus did not have any in stock @ $193 ouch , so I got a universal Bosch sensor. Ebay had a new one that I missed getting for $6
Lexus has a different part# for right and left and I when I checked the parts store for the bosch O2 sensor, they show the same # for the front right.and left. I think 1TYTESC used a passenger side O2 for the drivers side.
I was not sre if the OEM plug was different.
My guess is that the front O2's are 4wire pre-heated sensors and the rear are not? Is this correct.
Old May 6, 2006 | 02:07 PM
  #137
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Originally Posted by GILLEXUS
Pearlpower,
The sensor portion is the same for the O2 sensors. Just the length which explains the different Lexus part numbers. I went ahead and just installed new Bosch units left and right since I was in there anyhow. I hate paying for the same real estate twice. You should be fine.
Lee
Old May 6, 2006 | 04:27 PM
  #138
Hollywood's Avatar
Hollywood
Pearlpower,
There is an easy way to bypass the the cat sensors. Mechanically and not electrically.
Old May 7, 2006 | 03:49 AM
  #139
GILLEXUS's Avatar
GILLEXUS
Lee, thanks for the info, I'm I correct that the front and rear O2's are different?
Hollywood, why would you want to bypass the O2 sensors??
Old May 7, 2006 | 08:59 AM
  #140
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
The universal O2 sensors are the same front and rear. So a Bosch 15733 should work in any position on the car.
Old May 7, 2006 | 11:32 AM
  #141
Hollywood's Avatar
Hollywood
Just the ones for the cat check so you can delete the cats, u need the ones that fine tune the AF's in the headers.
Old May 7, 2006 | 02:45 PM
  #142
powmax's Avatar
powmax
would be great if someone can build some downpipe(s) that will replace the pre-cats???!!! maybe S&S will do some?
regards
marcus
Old May 7, 2006 | 03:54 PM
  #143
GILLEXUS's Avatar
GILLEXUS
Wouldn't that set off a CEL since it is an OBD II system?
Old May 7, 2006 | 04:08 PM
  #144
powmax's Avatar
powmax
yes - therefore you'll will need an O2-simulator (LINK )...
regards
marcus
Old May 7, 2006 | 04:45 PM
  #145
GILLEXUS's Avatar
GILLEXUS
regards
marcus
Thats cool thanks.
Old May 7, 2006 | 06:20 PM
  #146
Hollywood's Avatar
Hollywood
Yes normally it would but there is a trick to do "mechanically" which is the best way to do it and you can delete the cats and stil run the sensors in the test pipe. PM me if you want to know how to do it.
regards
marcus
This is an option, but has mixed reviews on longevity and cost. This is the electrical way of bypassing.
Old May 7, 2006 | 09:05 PM
  #147
GILLEXUS's Avatar
GILLEXUS
regards
marcus
Thats cool thanks.
Old May 8, 2006 | 05:15 AM
  #148
GILLEXUS's Avatar
GILLEXUS
Lee
FYI
I found this site which gives the lenth of the O2 wire, well that is for the walker brand. Not sure if this is the same lenth for OEM O2's..
Pass. side O2 17", driver side 10" and after cat. 27"
http://www.automedicsupply.com/catal...4.3L#Location1
Old May 22, 2006 | 10:05 PM
  #149
lspower's Avatar
lspower
yes straight pipe the third cat. as in goto a muffler shop and they will cut before and after the cat and weld in a straight piece of pipe (no o2 senors after the 3rd (useless) cat better mpg, more power all for under 70$ cant beat it
Old Aug 19, 2006 | 06:29 AM
  #150
Hameed's Avatar
Hameed
EV ftw!!!
Hey Lee, just ran into this thread and still cannot believe the amazing results you got with the headers install!
I had already decided to do this mod next year, but after reading your results, I want to do it now! Damn!
I have a freer flowing exhaust - bigger pipes (2.25 inch), eliminated all three resonators, added in an X-pipe, so I am hoping to get even better results with the headers!
