Opening Garage Doors
Old Dec 5, 2005 | 04:09 PM
Jim Herd's Avatar
Jim Herd
Default Opening Garage Doors
As you all know, we have three built-in garage door openers in the SC430 - cool! But modern garage door control systems are rather sophisticated - they change the digital codes frequently and automatically. And programming isn't as simple as it used to be. The opener in the garage and the car have to talk to each other and exchange codes.
Well, despite the fact that my wife is a computer scientist, she can't seem to program the darn opener to operate the security gate for our sub-division! Even the garage door itself was less than easy, though she did eventually suceed. She followed the same various procedures for the security gate (just a normal security gate control system), as described in the manual. Still, no joy.
Has anyone else had this problem?
Any advice on how to solve it?
Cheers,
Jim Herd
Old Dec 5, 2005 | 05:52 PM
koolaidman's Avatar
koolaidman
Cheers,
Jim Herd
read the manual its in there
Old Dec 5, 2005 | 07:06 PM
s2000's Avatar
s2000
for new openers with rolling security codes, you have to press the teach/ train botton on the garage door opener main unit, then rush to press one of the home link bottons within 30 seconds.
for older openers without rolling code, just press the remote opener and one of your lexus home link bottons simultaneously for 30 seconds or so.
hope this helps.
Old Dec 5, 2005 | 07:41 PM
tfischer's Avatar
tfischer
25 Year Member
As I recall, when I had to install a new opener in my garage about two years ago, it took me several (many) tries to program the new codes. I did have to use the "teach/train" button, located on the opener itself, as noted above, but my recollection is that not all 3 of the buttons in the car were able to learn it.
With my old opener, I quickly put the same code into all 3 buttons, just so I could push any one of them when I was really drunk and still open the door. With the new one, however, I was pushing "train" buttons on the opener itself and then in the car, and it took quite a while to get that code onto just one button. It would only take on the center button, but after that I did get one of the other buttons programed to turn on the lights, which is a feature I never use. (What's that for, anyway? The lights go on when the door goes up, and there's even a motion sensor on the wall button which turns on the lights when I just walk into the garage from the basement. I just can't figure out why I would want to turn on the lights inside the garage when I'm outside, other than just because I can.)
But I digress. My suggestion is to keep trying it with the different buttons in the car, because they may be receptive to memorizing codes differently. It makes no sense, and I may be generalizing from insufficient experience, but that's my story and I'm sticking with it.
Good luck.
Old Dec 6, 2005 | 12:17 AM
rominl's Avatar
rominl
exclusive matchup
program the button using the romote as usual.
then while the car is in the garage (make sure the garage door is clear), press on the learn button on the motor, and then press the button that you programmed. it will work
Goldie0526
Mar 5, 2012 10:10 PM
LexusK
Jul 25, 2008 07:46 AM
NAZTY97
RX - 1st Gen (1999-2003)
Oct 13, 2004 10:22 PM
