Trunk closed sensor
Old Jul 15, 2025 | 10:42 AM
Budheiser's Avatar
Budheiser
6th Gear
Default Trunk closed sensor
My 2005 SC has the red light on above the close top switch on the dash. The car thinks the trunk is open and the top will not open.
For a while we could slam the trunk down a couple of times and the light would go off.
Is there a sensor that notifies the car the trunk is closed so we are able to use the top or where do I look?
Thanks
Old Jul 15, 2025 | 05:52 PM
DshngDaryl's Avatar
DshngDaryl
Take a look at the trunk latch. I believe the sensor is in there
Old Jul 15, 2025 | 06:32 PM
Nevada's Avatar
Nevada
The trunk ajar light is in the gauge cluster. The warning light on the folding top switch is for top operation.
Inspect the cargo divider in the trunk, check for debris in the floor sockets where the cargo divider engages and the switch on the upper left side is activated.
Old Jul 16, 2025 | 04:51 AM
Budheiser's Avatar
Budheiser
6th Gear
Will give those a try
Thank you
Old Jul 23, 2025 | 12:28 PM
Budheiser's Avatar
Budheiser
6th Gear
Solved!
A friend of mine put his scanner on it and it was Front Lock Switch.
He took it apart, cleaned it, and put it back together
Problem Solved!
Old Jul 25, 2025 | 07:21 PM
GmanSC's Avatar
GmanSC
Originally Posted by Budheiser
Solved!
Problem Solved!
Front Lock Switch? Where is it located?
Old Jul 26, 2025 | 04:52 AM
Budheiser's Avatar
Budheiser
6th Gear
I don't really know. My friend with the scanner fixed it for me. Said he took it apart and cleaned it.
Fixed the problem
Budheiser
Maintenance
Aug 11, 2025 05:39 AM
Bigtexaslexus214
Jan 28, 2025 06:35 AM
komobu
Jan 28, 2024 05:22 AM
xjokerz
Oct 7, 2021 06:38 PM
Mr Jokster
Dec 7, 2008 03:54 AM
