AC Vents
Old Feb 26, 2024 | 07:44 AM
Lexpilot53's Avatar
Lexpilot53
Default AC Vents
Has anyone bought new AC vents? Mine do not work.
Old Feb 26, 2024 | 12:49 PM
DshngDaryl's Avatar
DshngDaryl
Can you be more specific? Does air not come out of them (bad actuator) or you can't direct the air the direction you want (bad vent) or the little slide goes back and forth, but the inside doesn't move?
Old Feb 26, 2024 | 04:20 PM
Lexpilot53's Avatar
Lexpilot53
Disintegrating from the Sun.
Old Feb 27, 2024 | 10:10 AM
DshngDaryl's Avatar
DshngDaryl
contact the guys from http://mylparts.com
They are a ClubLexus Vendor and will even give you a discount if you mention ClubLexus.com (or at least they used to)
They should be able to tell you if they can still get the parts. Otherwise you will have to go to the recycled market via ebay
Old Feb 28, 2024 | 02:16 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
i wonder if he means the foam is blowing out the vents or the plastic pieces making up the vent control is falling apart.
I replaced all of mine the old 2002.
Old Feb 28, 2024 | 05:50 AM
Lexpilot53's Avatar
Lexpilot53
The plastic parts on the left of the NAV screen that make the air go left and right and up and down have crumbled with the Sun. I just need the black plastic duct with the moving parts Found one on eBay for 50 bucks. I'm sure Toyota gets a fortune for it and they have probably been sitting on the shelf for 15 years.
Narift
Apr 12, 2023 05:48 AM
jdang0118
LS - 5th Gen (2018-present)
May 29, 2022 11:29 PM
biacs
Oct 4, 2017 08:05 AM
IStoSC
Sep 30, 2009 09:08 AM
2Fast0
May 4, 2006 07:10 PM
