Lower Arms replacement time
Old Nov 11, 2023 | 12:30 PM
pharaoh9's Avatar
pharaoh9
Default Lower Arms replacement time
Prepped for tomorrow, replacing the lower arms on both sides and the sway bar bushings since she is up. This will be fun to do with a jammed middle finger!
Actually pretty clean in here.
Old Nov 12, 2023 | 04:44 AM
Tanker's Avatar
Tanker
How many miles does it have?
Old Nov 12, 2023 | 05:36 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Are you replacing LCA #1 only or are you doing both LCA #1 & #2?
the bushings on LCA #2 might be worn out too.
I used these when i did mine.
https://tmengineering.net/webstore/i...4ae73b5805ed42
here is a thread
https://www.clublexus.com/forums/sc4...1-lca-2-a.html
Old Nov 12, 2023 | 06:09 AM
pharaoh9's Avatar
pharaoh9
She has 75k miles in her. After looking at the other components I have decided to pause and order the LCA #2’s, Stabilizers and Tire rods. I’ll end up doing the upper later.
Old Nov 12, 2023 | 06:17 AM
doobs's Avatar
doobs
You need LCAs after 75k miles?
Where do you drive, in the outback?
Old Nov 12, 2023 | 06:40 AM
pharaoh9's Avatar
pharaoh9
“Need” is a stretch I just figured I’m there let’s do it all and not worry for the rest of her life. I see torn bushings also.
Old Nov 12, 2023 | 07:15 AM
doobs's Avatar
doobs
Got it.
My '07 has ~65k miles on it and the underside bears no relation to yours, which is why I asked the question of where you were driving.
Old Nov 12, 2023 | 07:24 AM
pharaoh9's Avatar
pharaoh9
This is an 02 with 71k and was a Florida car. The couple I bought it from had it the last 14 years.
Mesca
Suspension
Jul 26, 2020 05:16 PM
Doublebase
Sep 25, 2017 03:11 PM
2GSTony
Suspension and Brakes
Dec 9, 2014 10:29 AM
SSxblazer
Apr 15, 2012 10:09 AM
gsCrazy
14
Apr 11, 2009 09:32 AM
