Techstream questions
Old Oct 18, 2023 | 02:48 PM
SGB4570's Avatar
SGB4570
Default Techstream questions
So I was out playing with my Techstream today and I have a few questions,
First: I get a code in history on my SRS airbags, B0106, and says, 'Open in P Squib circuit" Anyone have a clue what that is? and how to fix it? My SRS warning light only comes on randomly and I'd like it to stop. See pics.
Second: on my air-conditioning (it seems to work fine) I get B1421 and B1424 "solar sensor circuit", passenger and driver side. Again, fixes? This does not show up in the car as a warning light or anything.
Third: Looking at my front seat data, it states that the memory switches are in the OFF position, how do I go about changing these to on? It really probably doesn't matter but I knew the buttons do not work and I'd like to change it. seems like a safe first thing to try and change. I'm a little afraid of screwing something up on the car with this Techstream thing..
Thanks.
Old Oct 18, 2023 | 03:36 PM
GmanSC's Avatar
GmanSC
Thanks.
I can't help you with #1 but I can with #2 and #3.
#2: nothing wrong with your AC. The code shown because you did TechStream in the garage or shade.
#3: Your seat memory can be reset with the procedure found by search for ii.
Old Oct 18, 2023 | 03:40 PM
SGB4570's Avatar
SGB4570
Thanks on #2, and yes I was in the garage.
#3 So where do I search for this procedure?
Old Oct 18, 2023 | 03:59 PM
iolmaster's Avatar
iolmaster
Here is the procedure to re initialize the seat memory. Look at post #4.
https://www.clublexus.com/forums/sc4...d-working.html
Old Oct 18, 2023 | 04:20 PM
SGB4570's Avatar
SGB4570
read the whole thread, thanks. I’ll give it a try tomorrow, my only concern is it says I have to be in a park and there are no parks around here! ;-)
Old Oct 18, 2023 | 05:29 PM
DshngDaryl's Avatar
DshngDaryl
HA HA
Old Oct 18, 2023 | 09:25 PM
GmanSC's Avatar
GmanSC
Never thought about that. Very funny.
Old Oct 19, 2023 | 02:15 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Thanks.
item one…could be a loose connector or bad module. Did you or the previous owner have the passenger airbag inflator replaced as part of the massive recall?
if so, perhaps they didn’t plug the connector in all the way
read this thread please
https://www.clublexus.com/forums/sc4...0106-code.html
Old Oct 19, 2023 | 04:54 AM
SGB4570's Avatar
SGB4570
Yes, on the recall thing, went into the Lexus site and it says: Replace airbag inflator front passenger, recall 50061 Perform recall install module. on 6/10/2019 with 50061 miles.
As far as I can tell that module is under the center console, yes? Maybe unplug and replug it?
And again, that light going on is very random, sometimes yes, and sometimes no.
Old Oct 19, 2023 | 04:55 AM
SGB4570's Avatar
SGB4570
And back to the seat thing, I thought you could turn stuff off and on with the Techstream... yes? no?
Old Oct 19, 2023 | 06:02 AM
iolmaster's Avatar
iolmaster
Not always, sometimes it just let you know the state the system is in at the time. And Stevens Park isn't that far. Just go there. (inside joke)
Old Oct 19, 2023 | 06:52 AM
SGB4570's Avatar
SGB4570
HAHAHA!! As my kids say, are you creeping me? Yeah, that's about 4 miles from me.
And I'm still learning how this thing (Techstream) works. A lot to learn, and I think it works different on different cars maybe. I wish it would recognize and remember my car, and maybe that's a setting I have not found yet.
Old Oct 19, 2023 | 07:17 AM
GmanSC's Avatar
GmanSC
look into customization. That's all you can do with TechStream.
Old Oct 19, 2023 | 07:29 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
if the connector is in the console then check it there.
make sure the key is off for two min before you disconnect it. And see if it was not fully seated when disconnecting.
just be careful around the airbags…don’t want to set one off
Old Oct 19, 2023 | 07:58 AM
SGB4570's Avatar
SGB4570
As far as anything I have read, I need to disconnect the battery first, make sure there is no juice in the system.
