Washer fluid level sensor grommet leaking.
Old Apr 11, 2022 | 06:08 PM
Billy305's Avatar
Billy305
Default Washer fluid level sensor grommet leaking.
My 95 Sc300 washer fluid reservoir is leaking and I realized it was coming from the outside of the grommet for the level sensor. The grommet did seem a little dry and brittle. I researched and from what I found that grommet isn’t sold separately and the sensor is discontinued.
I ended up buying a used tank with the sensor and pump and sure enough that one leaks in the exact same place..
Does anyone know of a grommet that will fit or what I can use (aquarium sealer, epoxy, rtv, silicone etc) to seal between the rubber grommet and the plastic tank?
Id like to use the factory tank and ideally have the sensor still work.
Old Apr 11, 2022 | 06:18 PM
I made suggestions in the other thread you started did you try them?
Old Apr 11, 2022 | 07:08 PM
Billy305's Avatar
Billy305
wow I’ve been so busy I honestly forgot I made the other thread. Where would you put the oring?? In the grove of the grommet?
Old Apr 11, 2022 | 07:36 PM
What does the sensor look like under that original grommet? Will an O-ring stay in place?
Billy305
Mar 6, 2022 11:00 PM
Lexus4321
GX - 1st Gen (2003-2009)
Oct 28, 2021 09:46 AM
Dx3
Sep 5, 2016 07:40 PM
dashan
Jun 19, 2012 05:45 PM
