Cleaning an ABS sensor
Old Mar 12, 2022 | 10:12 PM
Billy305's Avatar
Billy305
Default Cleaning an ABS sensor
One of my rear abs sensors is not working properly and needs to be replaced. A new one is close to $300. I found a good deal on a used set from a sc parts dealer but from the pic they look like they have a bit of surface rust perhaps. Is there a good way to clean these up or should i just throw them in as is. Here is the pic he sent me:
Old Mar 15, 2022 | 01:59 PM
RXRodger's Avatar
RXRodger
I would clean up the outside of the bore. I have had them stick and difficult to remove from corrosion. Clean the tip to make sure metal dust/flakes doesn’t affect the signal. Other than that throw it in and roll. They rarely go bad unless damaged from a bad wheel bearing. You should be good with the used unit.
HtownBlue
Aug 25, 2024 06:48 PM
sbagdon
Apr 25, 2023 03:24 AM
NoobExe
Jul 13, 2021 11:14 PM
Darzan23
Apr 15, 2017 07:00 PM
tariqRX350
Jan 6, 2016 01:13 PM
