A/c stopped working
Old Feb 22, 2021 | 07:31 PM
ObSCessed's Avatar
ObSCessed
Default A/c stopped working
So my A/c has stopped blowing cold, 95 sc400. I notice it doesnt appear the compressor is turning on, normally turning the a/c on makes the rpm rise a bit in park, and the car will creep forward at low speeds, both have stopped occuring. Do I need to have ac recharged or compressor replaced? Or check fuses? Thanks
Old Feb 23, 2021 | 10:10 AM
RudysSC's Avatar
RudysSC
Typically the compressor won't turn off if it knows the system is low on refrigerant. I'd check that first, try a re-charge, and go from there! Doesn't ever hurt to check fuses as well just in case. As the compressors age they tend to pull a higher amp load.
Old Feb 23, 2021 | 11:37 AM
ObSCessed's Avatar
ObSCessed
thanks for the reply, just to make sure I understand, the car knows when refrigerant is too low and as such will not allow the compressor to work as a failsafe so it doesnt damage itself internally due to fluid starvation?
Old Feb 23, 2021 | 01:30 PM
RudysSC's Avatar
RudysSC
That is correct, yes sir! Most modern cars have a "pressure switch" that tells the compressor if it's safe to turn on. As far as I know the SC's are no different (someone please correct me if I'm wrong).
Old Feb 23, 2021 | 11:27 PM
ObSCessed's Avatar
ObSCessed
Interesting info, any thoughts on best replacement solution in this day and age, if thats needed?
Old Feb 24, 2021 | 04:12 AM
Bimmerbill's Avatar
Bimmerbill
Would go back with Denso on whatever you need for your A/C. It will cost more but you do not have to worry about one of those Chinese parts going bad. That was one of the reasons I bought my SC for $250. I had to replace everything and it is still going strong after soon be four years. It did cost me more but I do not have any regrets. Denso is what the factory used on our cars.
Old Feb 24, 2021 | 08:38 AM
ObSCessed's Avatar
ObSCessed
Will do thanks for the tip
Old Feb 24, 2021 | 11:30 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
check the a/c relay, alot of times the relay goes bad and that can happen. usually the compressor will kick on for a second before the high/low pressure sensor trips.
At first it is usually intermittent, you can try giving the relay a slight tap with a screwdriver and see if it frees up or wiggle it around.
Have had this happen on every 4runner and GX I have owned at some point, my old SC didn't do it but those relays are pretty old by now.
Old Feb 24, 2021 | 12:14 PM
ObSCessed's Avatar
ObSCessed
Thanks Ali, luckily I think I have a spare relay i got all the fuses and relays from a 94 part out a while back, any idea if their the same for all years or different?
Old Feb 24, 2021 | 12:48 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
check the part numbers on them, I think they would be the same as I don't think any of that stuff changed much over the years but I don't know for sure.
If it is the same shape and size prong wise then I would give it a quick try at the least. sometimes its just corrosion build up over the years and the prongs just need a good cleaning and put back in.
sometimes the a/c light will blink if the relay is bad, so that might be another sign, have also seen it blink due to low/high freon too though.
https://www.clublexus.com/forums/per...-engaging.html
05RollaXRS
RC F (2015-present)
33
Feb 28, 2021 10:50 PM
joey671
Jul 11, 2017 07:40 PM
Hybrid-JD
Aug 20, 2009 05:57 AM
Scotty93
Maintenance
Apr 12, 2008 06:43 PM
XSTeknique
Jun 7, 2006 12:40 PM
