Transmission fluid levels
Old Sep 2, 2017 | 03:14 PM
russvassar's Avatar
russvassar
Default Transmission fluid levels
Hi, I have just bought a 95 sc400. My trans fluid needs to be checked. Unfortunately no owners manual. Does my car need to be in park or neutral? To get the proper reading.
Old Sep 2, 2017 | 06:35 PM
ukrkoz's Avatar
ukrkoz
Why not ask in SC400 forum then?
Old Sep 4, 2017 | 06:22 AM
BiGEZ's Avatar
BiGEZ
You have to drive the car to warm up the fluids, the park on a level surface, move the shifter through gears from park to the lowest and back to park. Leave the car running and check the fluids. Trans fluid is checked with the car in park and engine running.
If you are going to do a drain and fill measure the amount of fluid that comes out and refill with the same amount.
It is recommended to use Toyota transmission fluid.
Old Sep 5, 2017 | 08:03 AM
RXRodger's Avatar
RXRodger
Huh? Where is this forum?
manifesto
May 5, 2018 10:23 AM
NSeagle78
Maintenance
Sep 20, 2015 02:26 AM
ISFer
IS F (2008-2014)
14
Apr 27, 2010 11:56 AM
trancez
Oct 15, 2008 07:47 PM
94GS3
Apr 26, 2001 11:34 AM
