Transmission fluid level.
Old May 4, 2018 | 11:12 AM
manifesto's Avatar
manifesto
Default Transmission fluid level.
Hi. In what condition should I check a transmission lvl fluid? When car is fully warmed after staying at parking spot or when I drove around 10-15 miles? . Becaus when I check after warmig at the parking spot, fluid lvl is below any mark of the dipstick, But when i check it after driving, lvl fluid is above hot mark.
Old May 4, 2018 | 11:39 AM
RVAGS400's Avatar
RVAGS400
You're supposed to check it after 10-15 minutes of driving, or really when it hits a certain temperature range. Believe it's like 150-170*F. I usually use my Torque Pro app to monitor transmission fluid temp and check when it's in that range.
Cycle through all gears P-R-N-D-3-2-1, go back to P (Park), and then check fluid level. Add fluid as required while engine is running in park. Always re-cycle through all the gears in between additions to verify how much you just added.
Old May 4, 2018 | 11:58 AM
manifesto's Avatar
manifesto
I also have Torque Pro. Can you tell me how to set transmission fluid temp gauge in app? Should I use a some kind equation, refering to this vid.
Old May 4, 2018 | 12:03 PM
RVAGS400's Avatar
RVAGS400
Equation? Can't watch the video while at work, but for me it was a simple task of just adding a digital display that shows transmission temperature. I also added a little graph that plots it over time, but that's really more for my 292k mile 4Runner than it is my Lexus.
Old May 5, 2018 | 01:57 AM
manifesto's Avatar
manifesto
Unfortunately this transmission temp display doesn't seem to be working (method 1 and 2) It doesn't display anything. I also tried method from video i posted (method 3 ) It shows some values but I dont believe it 'cuz it sometimes shows -49 C or something like that. My car gs300 98'
Old May 5, 2018 | 10:23 AM
VIP161's Avatar
VIP161
Thumbs up
This is quite possibly the best answer for the OPs question.
Miles253
12
Dec 13, 2015 09:16 AM
Davenlei
GX - 1st Gen (2003-2009)
Aug 24, 2014 01:09 AM
cal_alum98
Maintenance
Mar 14, 2014 12:53 AM
ISFer
IS F (2008-2014)
14
Apr 27, 2010 11:56 AM
94GS3
Apr 26, 2001 11:34 AM
