Install Sequential Switchback LED's without disassembling headlight
Old Aug 22, 2017 | 12:39 PM
raamblings's Avatar
raamblings
Default Install Sequential Switchback LED's without disassembling headlight
Hi Guys,
I wanna install some XKGlow sequential switchback lights in my headlight to mimic the Nike Swish that newer lexuses have.
I wanted to know if it was possible to install them without taking apart the headlight, because from what I've seen, its a fairly invasive process and I dont have any dew or moisture in my headlight and I dont want that to become a problem.
Also, Since our lights are lined (the diagonal magnification streaks across the front) would that mess up the way the LED Strip looks?
Here are some pictures of how my light looks currently.
Thanks in advance
Attached Thumbnails Install Sequential Switchback LED's without disassembling headlight-20170817_141851.jpg   Install Sequential Switchback LED's without disassembling headlight-20170817_211833.jpg   Install Sequential Switchback LED's without disassembling headlight-20170817_211905.jpg   Install Sequential Switchback LED's without disassembling headlight-20170817_141851-animation.gif
Old Aug 22, 2017 | 05:01 PM
Blkexcoupe's Avatar
Blkexcoupe
I'm not sure about the particular brand you're looking at, but most of those LED strips aren't weatherproofed to be installed outside of the headlight housing, so opening your headlights is the only option.
Old Aug 22, 2017 | 06:56 PM
mrmj2u's Avatar
mrmj2u
OG will handle this for you: https://www.organizedgaragestatus.com/running-lights
Old Aug 22, 2017 | 11:05 PM
raamblings's Avatar
raamblings
Default Feed led strip through opening for light
Hey thanks for that alternative.
however I don't want to spend that kind of money since my switchbacks only cost 100
And I was intending on installing them inside. There's no way they'd last outside the lens.
Is it possible to feed the light through hole and hope that it'll stick or is that just wishful thinking.
Old Aug 22, 2017 | 11:28 PM
Blkexcoupe's Avatar
Blkexcoupe
If you fed it through a hole on the back of the housing, then it would be between the black housing and the chrome trim. You want it to be between the clear lens and the chrome trim to be visible, so feeding it in isn't an option. The only way to properly install them is to split the lights.
jjboys
CT 200h Model (2011-2017)
Dec 28, 2015 06:12 PM
Jaytran
Feb 2, 2015 09:47 PM
schanel
Jan 2, 2015 12:24 PM
neomedic
Jan 12, 2012 07:34 AM
lachuy85
Feb 7, 2011 02:21 PM
