Custom Made Tail Light Color Mod
Old Jul 14, 2017 | 09:53 PM
Bootyman's Avatar
Bootyman
Default Custom Made Tail Light Color Mod
So here is my tail lights with a color mod in the works. Ideas while I got them open? What is the hands down best way to stop hyperflash if I go LED crazy?
Old Jul 15, 2017 | 09:18 AM
97-SC300's Avatar
97-SC300
Did you try to bleach out the yellow reverse lights? Wonder how you can get those to be pure white.
Old Jul 15, 2017 | 09:31 AM
Blkexcoupe's Avatar
Blkexcoupe
Which red paint did you use? I'm in the process of doing the same thing.
Do you think bleach would work? Polishing them does absolutely nothing.
*Edit* apparently hydrogen peroxide + oxiclean can work
Old Jul 15, 2017 | 09:48 AM
97-SC300's Avatar
97-SC300
I have no clue. Never had a set of tail lights apart.
Old Jul 15, 2017 | 09:57 AM
Blkexcoupe's Avatar
Blkexcoupe
Tint or vinyl will shrink when you heat the lights up to glue them back together. I ended up using Tamiya paints for RC cars to smoke the reverse lens. I have my concerns about them fading in the sun, so I'll probably shoot everything with Spraymax 2k clear once I'm done.
Spray the smoke lighter than you would want, then install them. I sprayed it until I got the desired look I wanted, but once I put the lens back on it was too dark for my liking.
Old Jul 15, 2017 | 10:06 AM
Bootyman's Avatar
Bootyman
How many coats of smoke did you do? Is it difficult to visually see the white warning lights when the car is put in reverse? I'm going 2 coats of the smoke, tops, then the 2k clear too.
Old Jul 15, 2017 | 10:11 AM
Blkexcoupe's Avatar
Blkexcoupe
That was 2 coats. First one was heavier than necessary.
That picture was taken last night. I don't know about light output since the lights aren't assembled yet. I still need to find a red paint that will match.
Old Jul 15, 2017 | 12:31 PM
TacMedDoc's Avatar
TacMedDoc
Down to see the finished product
Old Jul 15, 2017 | 03:46 PM
Zerodrag's Avatar
Zerodrag
A long time ago, we used to use this hobby paint for a red coating on lenses.
https://www.scalehobbyist.com/manufa...05/product.php
Old Jul 15, 2017 | 06:49 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
I've always wanted a pair of 97 taillights that were completely gloss black that still had the chrome trim. It would look so nice.
Old Jul 18, 2017 | 09:08 PM
Blkexcoupe's Avatar
Blkexcoupe
I did some more research into this, and I don't think it's possible. I've had my spare lights soaking in a hydrogen peroxide solution for a few days, and there is almost no change. The lens has yellowed all the way though and it's still smooth.
The good news is, this part is fairly simple and could be thermal formed to make a replacement part similar to what clear corners does for their tail lights.
Old Jul 19, 2017 | 05:50 AM
mrmj2u's Avatar
mrmj2u
As for hyperblink, there are four methods, but three that have been confirmed to work on the 92-94:
1. Shave the resistor - https://www.clublexus.com/forums/sc-...ml#post9906362
2. Solder in diodes - https://www.clublexus.com/forums/per...ml#post5470969
3. Add resisters behind each led - most expensive route
4. Purchase a new flasher relay. I've tried the common 3 prong relay, but it did not work on my '92. I hear that there is a 5 pin relay out there somewhere, but I did not see it when I was looking. I have also not seen anyone use one successfully. - This was mentioned in this thread https://www.clublexus.com/forums/per...llights-6.html - If a link to the amazon relay is posted, I will edit this post again.
EDIT: #4 has been confirmed to NOT work.
I chose #2
I have leds in all the flashers (front and back) and don't have any issues.
Old Jul 19, 2017 | 07:00 PM
Hil's Avatar
Hil
Maybe if he has access to a 3D scanner, scan the lens, and 3D print a new pair in a clear material
Old Jul 20, 2017 | 05:20 PM
Blkexcoupe's Avatar
Blkexcoupe
A frosted plastic might work, but then you would run into issues of how the printed plastic will disperse the light. It might look really weird when illuminated.
Old Jul 21, 2017 | 10:53 AM
Organized Garage Status's Avatar
Former Sponsor
If there's enough demand for it, we can manufacture an exact replica of the yellow turn signal diffuser into a red. Minimum of 10 sets and its on.
