SC- 1st Gen (1992-2000)
92-94 Flasher Mod: Solution for LED Tails
Old 07-11-17, 11:20 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
Originally Posted by super400
i used a the sanding drum attachment on my dremel. I don't think sandpaper would be hard enough. Even if it was your hand will probably fall off before you get it finished. The no hyperblink life is fantastic. I put up with it for over a year, it drove me insane.
I will have to borrow a Dremel then. I have dealt with hyperblink for over seven years and it drove me nuts.
Old 07-11-17, 11:28 AM
aletz12485
aletz12485's Avatar
OP, did you try to use an aftermarket 3-prong LED flasher? I saw another thread of yours where someone mentioned to use one. Wondering if it worked or not? Im guessing not, based on this thread.
Old 07-11-17, 11:34 AM
mrmj2u
mrmj2u's Avatar
The three prong does not work for the 92-94 model cars.
I tried it...
Old 07-11-17, 12:47 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
I tried it...
That's good to know. I almost bought one a while back.
Old 07-12-17, 09:34 AM
super400
super400's Avatar
the 92-94 is a 5 prong relay. I even tried a 5 prong relay. It didn't work, I think those are made for fords? I have a feeling, like most things on these cars, the oem flasher is a custom thing just for the SC's.
Old 08-29-17, 11:17 PM
Organized Garage Status
Former Sponsor
Organized Garage Status's Avatar
Can we get a sticky on this please. Thank you.
Old 07-06-19, 11:08 AM
goes2fast
goes2fast's Avatar
Default Turn Flasher
I went to replace my flasher and everything shows a 3 prong flasher for an SC300 but mine is a 5 prong? I need to get an electronic flasher to fix my hyper flash caused by switching to LEDs and I don't want to order the wrong one. Thanks for any help!
Old 07-07-19, 09:34 AM
goes2fast
goes2fast's Avatar
Is anyone still on here? Where can I go to get help working on my SC?
Old 07-07-19, 09:55 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Let's start off by getting the post out of the engine & performance section to the right spot
Second, suggest searching for past threads for ideas - help yourself! There are 20 years worth of posts and likely already been asked and answered.
I searched for 'flash prong' and here are a couple of links to get started. You could also try searching for hyperflash and hyper flash
https://www.clublexus.com/forums/per...aillights.html
https://www.clublexus.com/forums/sc-...n-t-flash.html
https://www.clublexus.com/forums/sc-...led-tails.html
Old 07-07-19, 11:37 AM
goes2fast
goes2fast's Avatar
Default Thanks
I did a search and didn't have much luck. The first thread had a lot of links that no longer worked and the last one has the best fix that I'm about to try. When I started the thread the category just said maintenance and repairs, I didn't see anything about engines, so a little confusing. Now if I could find some help figuring out why my radio quit working while the car was parked I will be back in business, and I also did a search for that one with no luck as well.
Old 07-07-19, 01:44 PM
goes2fast
goes2fast's Avatar
I just did this mod and it worked great after taking it down to about 1/3 the original size, thanks!
DaveGS4 (07-08-19)
Brandicus
09-07-16 07:55 AM
CARSNBIKES
08-11-15 01:35 PM
spin420
03-03-12 05:05 PM
1GStoEnvy
09-27-09 11:46 PM
MrG4Life
09-14-09 08:18 AM
Quick Reply: 92-94 Flasher Mod: Solution for LED Tails
