Need camber issue answer
Old May 12, 2003 | 04:12 PM
Tim's Avatar
Tim
Default Need camber issue answer
Well this weekend i changed my control arms bushing and changed the suspension to Eibach Pro kit/ tokiko shocks setup. So do i need a camber kit for alignment, if so is their some available for the SC400? I called a few alignment shops and they said i needed a camber kit to get my alignment done. Some places said they could align the car to factory specs, would that be sufficient for the drop. I've searched the threads but haven't found any answers.....
Old May 14, 2003 | 06:37 AM
aasc300's Avatar
aasc300
I am also interested in finding a camber kit for the sc. I installed tokico blues and eibach pro-kits on my car and I can tell there is some negative camber. Where the lower control arms mount to the chassis, there appears to be a camber adjustment. The alignment shop that is going to do the alignment should be able to set the car to factory specs and that will be sufficient, you may even want to run a little negative to improve your handling characteristics.
Old May 14, 2003 | 09:47 PM
pcmw's Avatar
pcmw
No camber kit yet. TMEngineering.com is working on a set.
MW
edgeucated
Suspension and Brakes
Dec 2, 2012 09:38 PM
Trendzero
Mar 13, 2012 06:24 PM
stlgrym3
Mar 3, 2012 03:48 PM
no1gsxr
Jan 3, 2009 01:46 PM
ted920
May 3, 2004 01:00 PM
