airbag code 12 after rx swap
Old Aug 25, 2016 | 09:12 AM
Deathbarel's Avatar
Deathbarel
Default airbag code 12 after rx swap
i installed a rx300 wheel and bag and now i have air bag code 12? does anyone know what this means code 12 is high resistance in circuit
Old Aug 25, 2016 | 01:30 PM
t2d2's Avatar
t2d2
I don't know what exactly that means or how to safely measure the resistance without blowing the bag, but you could try disconnecting it and placing a 2 ohm 1/4 watt resistor on the harness side and see if that defeats the light. If it does, then you've confirmed that the issue is with the airbag, as opposed to something that went wrong during the swap.
Old Aug 25, 2016 | 05:17 PM
gerrb's Avatar
gerrb
Super Moderator
Did you disconnect the battery when you did the work ?
Old Aug 26, 2016 | 07:05 AM
Deathbarel's Avatar
Deathbarel
yes. does anyone know what happens if you put a dual stage bag in the sc
oraneivey
Jan 12, 2017 12:02 PM
Deathbarel
Aug 14, 2016 06:06 AM
Egone
May 11, 2011 10:24 AM
Chungstyle
Feb 17, 2006 12:25 PM
