Brake Pad Changing Procedure
Old Mar 25, 2003 | 07:06 PM
heyma's Avatar
heyma
Question Brake Pad Changing Procedure
I will be changing the brake pads for a 93 SC 400 soon and was wondering if there is a pre-written procedure out there I can go by. I searched the archives already, but can't find a thorough write-up.
Thanks!
Old Mar 25, 2003 | 08:45 PM
V8RWDHP's Avatar
V8RWDHP
I haven't done my fronts yet but the rears are just about as easy as a brake job can get. Just pull out the top bolt and pivot the caliper on the bottom one. If you've ever done brakes before you'll know what I mean and have no problem whatsoever.
Old Mar 25, 2003 | 11:03 PM
philauldridge's Avatar
philauldridge
Default changing brake pads
He's exactly right. Changing the pads on a Lexus couldn't be easier. You really won't need instructions. Yank the wheel off (jack stands, of course!), pull out the two retaining pins, slip out the old, and slip in the new (you'll have to spread the calipers slightly for the wider new pads... one of those handy little caliper spreading tools from Pep boys is great, otherwise, just carefully use a blunt pry bar to slowly open them up). If you've ever replaced the pads on a BMW, you'll be grateful you have a Lexus!
silkx3
Suspension and Brakes
Mar 6, 2016 07:05 PM
LexGX460
GX - 2nd Gen (2010-2023)
Aug 17, 2015 12:38 PM
ZeusES300
Mar 10, 2015 10:14 AM
reverndlex
14
Nov 11, 2014 04:39 AM
gsCrazy
Mar 13, 2007 08:16 PM
