Help! A/C control unit Not working?
Old Mar 24, 2003 | 08:44 AM
LEXBOGGY's Avatar
LEXBOGGY
Exclamation Help! A/C control unit Not working?
My a/c control head went out this week end and I have no clue to what happen? Has anyone else had this troublem? I checked the fuses and they were good. Can someone help me out?
Old Mar 24, 2003 | 08:57 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
check the under hood fuses as WELL AS the kick panel.
does the display not light up at all? no lcd output, no air, no blower function?
Old Mar 24, 2003 | 09:16 AM
LEXBOGGY's Avatar
LEXBOGGY
No Display, no blower, but the back light comes on with the instrutments
Old Mar 24, 2003 | 09:58 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
there is only a 10% chance the unit is internally corrupt, but there IS a chance. i feel it is somewhere within the contacts on the fuses. some fuses are double related so pull each one out one by one and make sure there is no corrosion. it also may help you by just doing that because there was a thread here a while back where someone had a contact problem with the fusebox and did the same thing and it worked fine thereafter.
Old Mar 25, 2003 | 09:47 AM
LEXBOGGY's Avatar
LEXBOGGY
Thanks, I went and checked all the fuses under the hood first and then i checked the ones on the kick panel and found that the cigerite lighter fuse had blown and that was what cause my A/C panel not to function. Tahnks buddy.
Old Mar 25, 2003 | 09:55 AM
jimmit's Avatar
jimmit
I had a similar problem a month or two ago and for me it was a really easy fix. Have you used your lighter plug for anything? Cell phone charger or AC converter? Check the kick panel fuse again for the cigerette lighter because the AC display and cig. lighter fuses are one so 90% chance its your fuse. After you check the fuses check them again, its pretty easy to pass up a bad fuse unless you look very closely sometimes. Also if you have something like a radar dector or anything connected to the lighter wire then check the wire too and make sure its not causing any problems
Old Mar 25, 2003 | 10:06 AM
LEXBOGGY's Avatar
LEXBOGGY
No my wife used my car to go to work on Sat. because she was to lazy to put gas in her car and she droped a penny in the lighter socket causing the short. be cause neither one of us smoke she did know the fuse had blown.
Old Aug 5, 2003 | 08:14 PM
92sc's Avatar
92sc
Fixed my problem too. Thanks! I love this board!
Old Aug 5, 2003 | 08:18 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
That's great to hear, welcome to CL.
GOLDSc300
May 24, 2020 06:05 PM
2JZSoarer
Feb 4, 2010 12:14 PM
Wicked GS
Florida Lexus Club
Sep 25, 2009 04:09 PM
thinhthan
May 31, 2008 09:14 PM
surfsunset
Jun 5, 2006 10:34 AM
