ABS Codes
However I've had an air-bag light on in my dash since the Previous owner, who stated it came on when he had the viper alarm installed and they removed the gauge cluster. And when I jumped the ports I got the airbag code (code 41), which I expected, however the ABS light did not blink at all. It just stayed on, which I'm unsure if that means anything since all of the dash lights stay on anyways when the key is in ACC. However, this page says that if the ABS light stays on there is a malfunction in the ECU.
http://www.lexls.com/tutorials/intro/codereading.html
So has anyone else tested their ABS system? If so what did you get, and does the always on mean there's an ECU malfunction, or does it mean something else? Would an air-bag light stop the ABS light from blinking? Any help or input is appreciated, as I would hate to have a mechanic or the dealership fix this if I can do it myself.
I'm not really looking for any help with the air-bag light, I just included it in case it was relevant to the ABS light, I'm fully aware of how to reset the air-bag light, it just isn't a priority for me right now.
Did you remove that jumper when checking for ABS codes? It's necessary to do so, as I recall. The SC300 could be different, but I think those instructions applied to both. It's a very vague and confusing aspect.
By the diagnostic box you are referring to the obd1 diagnostic port, or are you referring to somewhere else? I'm not familiar with the term.
https://www.clublexus.com/forums/per...ml#post6124292
That's the one that made me do a double take, having recovered that little 2-pin jumper (bottom right) from down in the engine valley. It's for pins WA and WB, as covered in the factory service manual on BR-52, pg 1021 in my PDF version.
http://www.justanswer.com/lexus/3q85...97-causes.html
It took me quite a bit of searching to find any info on that jumper and what role it serves.
ABS codes can only be checked when the jumper is removed from the diagnostics box..
After removing the jumper I'm getting code 35, which is a short in the vehicle speed sensor in either the front left, or rear right wheel. Makes this quite a bit easier for me. Hopefully this problem will have an easy/cheap solution, but I've got the car in the air now and I'm going through the sensors.
