Old Dec 15, 2014, 01:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Check engine light
Old Nov 29, 2014 | 01:16 PM
Rickbean's Avatar
Rickbean
Default Check engine light
Does anyone know how I can figure out why my engine light is on. I have a 95 sc300 I took it to the auto zone and the guy told me they can't hook it up To a computer? Any suggestions will be appreciated
Old Nov 29, 2014 | 01:39 PM
scENFORCER's Avatar
scENFORCER
Take it to a real mechanic.
Old Nov 29, 2014 | 01:52 PM
tfwnoturbo's Avatar
tfwnoturbo
You seriously took it to Auto Zone as your first choice?
As enforcer said, take it to a dedicated shop, not to the walmart of Auto Parts.
That or use your own code scanner to figure out the code.
Old Nov 29, 2014 | 02:10 PM
t2d2's Avatar
t2d2
Geez fellas, take it easy on the new guy. Some Auto Zones, like the two nearest me, are filled with very knowledgeable car guys. Obviously, that's not true everywhere, but the OP's decision to go there first isn't necessarily a bad one just because your experiences have been poor. Everyone's had a bad mechanic at some point, but I don't hear anyone saying to avoid mechanics altogether as a result.
Old Nov 29, 2014 | 02:28 PM
Black1UZ's Avatar
Black1UZ
Or you can buy a little scanner for less than 30 bucks that spots the codes and you can look them up. Save yourself money and time
Old Nov 29, 2014 | 03:08 PM
FastTags's Avatar
FastTags
OBD2 works on 1996 and up vehicles. Cars before 1996 did not have a slot, the only way is to hook it up directly to computer which some mechanic shop will have but not the Autozone
Old Nov 29, 2014 | 03:55 PM
t2d2's Avatar
t2d2
Or the other "only way" of jumpering the engine diagnostic port pins with a paperclip.
jumper E1 & TE1, then turn ignition to "On" and count CEL flashes.
e.g. code 71 (egr) = 7 blinks, pause, 1 blink, long pause, repeat.
OBDI Trouble Codes:
12/13 RPM Signal
14/15 Ignition Signal
16 Electronically Controlled Transmission Control Signal
17/18 CMP #1/2
21 Main O2S & Heater Signal
22 ECT Sensor Signal
24 IAT Sensor Signal
25 Air-Fuel Ratio Lean Malfunction
26 Air-Fuel Ratio Rich Malfunction
27 Sub O2S Signal
28 Main O2S
29 Sub O2S
31/32 Air Flow Meter Signal
35 HAC/Barometric Pressure Sensor Signal
41 TP Sensor Signal
42 VSS Signal
43 Starter Signal
47 Sub TP Sensor
48 Secondary Injection System Malfunction
51 Switch Condition Signal
52/55 Knock Senosor (KS) #1/2 Signal
53 Knock Control Signal
70/71 EGR System Malfunction
78 Fuel Pump Control
The constant blinking of the check engine and O/D means it hasnt thrown any codes.
Old Nov 30, 2014 | 12:22 AM
2jznosht's Avatar
2jznosht
I almost lost hope there...op, do what t2d2 said and check back
Old Dec 2, 2014 | 11:40 PM
Twojaybee's Avatar
Twojaybee
I know it says ls400 but follow the procedure, has pictures too.
Worked on my 93 sc300. Super easy, just gotta pay attention to the CEL when it blinks. I got this bookmarked just in case mines ever decides to show up again. Click the link or copy n paste it in a new window for easy instructions with pics!!
http://www.lexls.com/tutorials/intro/codereading.html
You're welcome!!
Old Dec 4, 2014 | 09:02 PM
salimshah's Avatar
salimshah
25 Year Member
Any suggestions on how to read CEL that comes on and then goes away? By the time I get home the CEL is off. One option is it ignore it till the light comes on and stays on.
OBDII has pending codes, is there some thing like Pending Codes with OBDI?
Vehicle is 95 SC400
Salim
Old Dec 4, 2014 | 10:54 PM
oldManTan's Avatar
oldManTan
Vehicle is 95 SC400
Salim
just check the codes right away, stick the paperclip in and count the blinks
Old Dec 5, 2014 | 12:15 PM
salimshah's Avatar
salimshah
25 Year Member
You are not suggesting I do that in middle of a Hwy
Salim
jasonlee
Oct 19, 2009 11:53 AM
McMuffin
Nov 2, 2008 05:20 PM
lexushelp
Aug 11, 2007 02:22 PM
Nat
Jan 18, 2007 09:37 PM
Bill1964
Aug 12, 2003 11:18 PM
