Aftermarket header problems
Old Oct 2, 2014 | 03:21 PM
BlackIRON's Avatar
BlackIRON
Default Aftermarket header problems
So after installing an aftermarket header my car is burning extremely rich and i have no idea how to fix it i mean if i replace the sensors assuming they arent working wouldnt they get the same reading and not fix the problem? i have absolutely no catalytic converter. somebody please help my MPG's are sucking
Old Oct 2, 2014 | 05:01 PM
turbodremz's Avatar
turbodremz
Generally with no catalytic you should gain some mpg's (in theory), but the car will smell rich without the cats. Are you running open headers, or connected through the rest of the exhaust? Do you have both pre and post cat o2's connected? Any cel? Something is off (obviously) but it needs to be traced down. How old are the o2 sensors?
Old Oct 2, 2014 | 05:46 PM
oldManTan's Avatar
oldManTan
is this a 300 or 400?
Old Oct 2, 2014 | 05:47 PM
BlackIRON's Avatar
BlackIRON
one upstream is new and one downstream is new. the header itself goes from the exhaust manifold down to the actual exhaust but i am using the stock toyota muflfers. I thought the smell may be that the phlange was lose but its not the case. i do have a CEL on and it says its ALL o2's, should i just replace all four?
Old Oct 2, 2014 | 06:53 PM
AnonymousG's Avatar
AnonymousG
Did you try resetting the ecu by removing the efi relay.
Old Oct 2, 2014 | 08:35 PM
Kris9884's Avatar
Kris9884
What kind of car? I assume a SC400 since no one really tries to get NA power out of the 2J, right? Is everything plugged back in? Any wires get left on the exhaust and melt? I'd reset the ECU by removing the terminals on the battery and let it set. Try doing that and then resetting the codes at AutoZone and test...
Old Oct 2, 2014 | 11:00 PM
BlackIRON's Avatar
BlackIRON
it is a 96 300 and im prepping it for a turbo. Before i put in the injectors i want to fix my fuel mixture and MPG issue.
Old Oct 2, 2014 | 11:01 PM
AnonymousG's Avatar
AnonymousG
If you're prepping it for turbo, why did you install a header for?
Old Oct 2, 2014 | 11:03 PM
BlackIRON's Avatar
BlackIRON
I had one laying around from a 94 i parted out that sounded nice and figured it would be better than stock exhaust
Old Oct 3, 2014 | 09:49 AM
turbodremz's Avatar
turbodremz
If your having MPG issues, might want to rethink the turbo and larger injectors.
Not trying to be a jerk, but if your prepping for a turbo may as well get associated with lower MPG. Now, the rich fuel smell will NOT go away without having atleast one cat in place, regardless of how long your exhaust is. My LS1 SC has exhaust all the way back to the diff, with no cats and it burns my eyes especially on cold starts (I hate trees, and carbon foot prints are garbage.) So the smell probably isnt an issue.
How many MPG's did you average BEFORE the headers, and whats your average now? How does the car idle? Is it at the correct rpm? Does it surge? How does it accelerate? Are you still driving the same? Did you double check to be sure everything (specifically any vacuum lines) were reinstalled properly?
Old Oct 3, 2014 | 11:10 AM
Kris9884's Avatar
Kris9884
Lol about the trees. All the right questions here though.
Old Oct 3, 2014 | 03:44 PM
1997Soarer's Avatar
1997Soarer
I'd reset the ecu.
Your car is obd2 so you can use an obd scanner to check all the codes. Resetting the ecu will clear old codes, and if you still have issues they should show up as codes. Then go from there
BIGCAM24
IS - 1st Gen (2001-2005)
May 29, 2018 04:31 PM
LexXxuS101
May 3, 2013 04:11 PM
superpet39
Apr 12, 2013 01:43 PM
hungsmurf
IS F (2008-2014)
Apr 25, 2012 03:34 PM
Keith13b
Mar 8, 2002 05:52 PM
