SC- 1st Gen (1992-2000)
Double Din Help!
Old 07-22-14, 10:35 AM
Whitehawk
Whitehawk's Avatar
Default Double Din Help!
I have installed a Pioneer AVIC 5000NEX in my 1999 SC300. Everything works except it won't let me past the License agreement on the NAV system. Pioneer said to hook up the parking brake wire but I can't find the wire for the positive side of the parking brake switch. What color is it and where do I tap in? Thanks
Old 07-22-14, 12:46 PM
t2d2
t2d2's Avatar
Here are a few threads I followed in figuring out my stereo stuff. You may (or may not) find your answer in one of the wiring or harness diagrams:
https://www.clublexus.com/forums/lex...b-working.html
https://www.clublexus.com/forums/lex...ead-units.html
https://www.clublexus.com/forums/lex...sc3-400-a.html
https://www.clublexus.com/forums/sc-...r-rebuild.html
https://www.clublexus.com/forums/sc-...ring-help.html
Old 07-22-14, 01:21 PM
Whitehawk
Whitehawk's Avatar
Good suggestions but none address my problem, thanks anyway.
Old 07-22-14, 02:17 PM
Ali SC3
Ali SC3's Avatar
there is just 1 wire from the headunit for the parking brake and you either connect it to the parking brake switch or just to get it working you can just connect it to ground (side of the stereo or any metal its touching).
Old 07-23-14, 04:18 PM
Whitehawk
Whitehawk's Avatar
I decided to just ground it stop worrying about it, works fine, Thanks
Old 07-24-14, 03:15 PM
BAD954BOI
BAD954BOI's Avatar
how do you like the headunit i was looking at the same unit.
REVIEW PLEASE!!!
Old 07-24-14, 05:45 PM
sc300bigtx
sc300bigtx's Avatar
Anyone offer some help installing aftermarket stereo into a 99 sc300
This year models factory wiring is completely different then my previous older sc
I've ordered the specific amp integration harness I used in the past but doesn't work
Old 07-26-14, 11:56 AM
Cleanshots
Cleanshots's Avatar
find the wire on the double din and just ground it.. that way the issue goes away and you can watch movies while you drive.. lol
wise2k
12-23-12 03:16 AM
Levante92
IS - 1st Gen (2001-2005)
10-08-12 01:13 AM
vicious
13
12-05-11 09:14 AM
FutureSC
06-04-10 06:00 PM
lexus2u
12-24-07 05:23 PM
Quick Reply: Double Din Help!
