Err Err Err code on replacement CD changer
Old May 9, 2014 | 11:29 AM
moretoys's Avatar
moretoys
Default Err Err Err code on replacement CD changer
Got a 92-96 ES300 6CD changer off ebay & installed. It is still throwing the Error code.
Is there a reset button? Is there a trick to sync it with the head unit?
Nakamichi head unit displays communication with unit in every way and unit makes all the right noises then goes to Err. Please help and thanks in advance.
Does the unit need to be grounded to work? I just tested it laying near the hole for the old one. Thanks
Old May 10, 2014 | 09:32 AM
kilroy45's Avatar
kilroy45
Default cd changer
I have a cd changer from my 96. I put it in my 92 sc300. So I have the same one you have.
1st make sure the CDs are in correctly (Ive done this when I first used it)
2nd make sure the arrow on the CD cartridge face the arrow on the lid.
3rd with the lid open, feel at the bottom corner inside the lid (8 o clock position?) Its on side closest to tail lights and open portion of trunk its a small little black dot of a button (this is the rest button) I can send a pic of mine once Im home from car show if you need
Old May 10, 2014 | 08:38 PM
moretoys's Avatar
moretoys
No Kilroy you don't have the same one I have. Mine is the much talked about direct plug and play replacement of the 12 CD unit that came in the SC3 & SC4. I see no reset button on the ES 6CD changer,
Anyone else have any sugestions?
Old May 12, 2014 | 07:35 PM
kilroy45's Avatar
kilroy45
Misread it as an SC cd changer sorry but I tried. And I don't think its much talked about...otherwise you could find it by searching forums instead . If its an es changer why not jump over there to ES section..
Old May 17, 2014 | 08:39 PM
E36M3's Avatar
E36M3
Kilroy, I'm getting the same error. Do you have a pic of the reset button. Thanks.
Old May 17, 2014 | 09:49 PM
E36M3's Avatar
E36M3
Update! I found the reset button. Pressed it but no avail. Is there a special method to reset it fot it to work? Appreciate the help!
Old May 20, 2014 | 02:13 PM
kilroy45's Avatar
kilroy45
Cool
Originally Posted by e36m3
kilroy, i'm getting the same error. Do you have a pic of the reset button. Thanks.
Old May 20, 2014 | 02:14 PM
kilroy45's Avatar
kilroy45
Yes you have to open it up. And press and hold the button. It will reload all cds back to cartridge then it raises up
Old May 26, 2014 | 08:30 AM
E36M3's Avatar
E36M3
I did exactly you said. Load the discs, error appeared, opened cd changer, pressed and held button but nothing happened. What am i doing wrong?
Old May 26, 2014 | 08:59 AM
Luxor's Avatar
Luxor
Try using a regular CD rather than a burned CD-R disc. Maybe it can't read burned CDs.
Old Jun 1, 2014 | 09:16 PM
E36M3's Avatar
E36M3
I tried that too to no avail. I don't know what I'm doing wrong.
Old Jun 27, 2014 | 06:22 AM
Sweatshop's Avatar
Sweatshop
Clean the lens. Clean the lens. Clean the lens. Four dollar disc with a lil brush on it. Pop it in and play it a few times. Works wonders.
Stereorob
Dec 7, 2014 07:30 PM
parker770
Feb 28, 2006 03:27 PM
v8pwr
Apr 8, 2004 01:22 PM
Balzak
Apr 30, 2002 02:32 PM
