Mvp headers
Old Apr 9, 2014 | 09:06 PM
x2jzsc300x's Avatar
x2jzsc300x
Default Mvp headers
So I've doing a lot of research and debating either to even get headers anymore when I looked up obx people complained it cracked and the welding and fitment is off when looked up mvp headers I was aiming for that until I found out people are getting check engine lights but it's like 50% do and don't trying to figure out why would they get cel ? Should I keep stock really don't want to but if I have to how can I avoid getting a cel ? Please help need more hp lol
Old Apr 9, 2014 | 09:34 PM
KahnBB6's Avatar
KahnBB6
In Cali you will have trouble with this. Especially if you have a Cali-spec car and not a Federal car. I considered it for an extra 8-10hp and some extra pull up high but the CEL issue might plague you even on an OBD1. There are O2 simulators available but I can't say for certain if this will help with the Cali-spec #3 O2 sensor (which more or less checks "efficiency" and does not report actual varying signals-- as far as I know).
There are a specific set of Bosch (I think) O2 screw-in sensors that are needed for this header.
In general, I don't see the benefit unless this is a 2JZ-GE swapped into a lightweight chassis like a 240SX set up for weekend track use. It's such a minor difference in power and a shift in the torque delivery from the low end to the higher rev range-- which makes more sense in a car that weighs under 3000lbs. On the street the SC300 needs all the low down torque it can get. I'd pair this with a 4.27 ratio if you aren't running one already.
MVP's headers, however, are supposed to be the good ones to buy if you so choose to.
Old Apr 11, 2014 | 08:05 PM
jjffyy's Avatar
jjffyy
I have a set of MVP headers on my car and have been running it for 3 years now without a cel, although I did have to buy some universal screw in type O2 sensors and splice them to the stock connectors. The only reason I got it in the first place was because my stock header had cracked. The MVP header did help a bit on the top end but like KhanBB6 said the car is too heavy to really feel any substantial gain. As for the cel problem this is actually the first time I've heard about it, maybe some people are using the wrong O2 sensors or did not splice the wires correctly?? I'm not really sure.
Old Apr 12, 2014 | 06:07 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
The MVP header is supposed to be pretty good. Does it make the exhaust louder or change the sound?
Old Apr 13, 2014 | 10:17 AM
x2jzsc300x's Avatar
x2jzsc300x
Yea it makes really raspy but it sounds like a supra 😀
Old May 2, 2014 | 11:33 AM
1997Soarer's Avatar
1997Soarer
Yeah, it increases rasp a lot. How badly depends on the exhaust you're running now (stock vs straight pipe, etc). A good setup is the mvp header + Blitz front pipe + Blitz catback. Yeah it's loud enough to get tickets, but you'll sound a LOT like a modded TT supra.
I'll agree with everyone else. The header doesn't really add any power unless you like to drive above 4000rpm a lot. It hurts daily driving, especially if you're auto.
HotSoup
14
Feb 12, 2018 03:11 AM
Rider
IS F (2008-2014)
15
Oct 7, 2015 06:58 AM
toyer14
IS F (2008-2014)
16
Sep 19, 2015 07:12 PM
MrPhung
Performance
25
Mar 23, 2012 05:23 PM
