Sunroof problems
Old Apr 9, 2014 | 10:12 AM
khmersta's Avatar
khmersta
Default Sunroof problems
Hello CL, recently I've been replacing some old parts out of my 97 sc300. I've ran into a sunroof problem, I used to take advantage of opening/tilting it but, now it seems like the left side only works. Sunroof opens fine but, the right side will not retract and close all the way, stops about 3 inches before closing I have to manually pull the right side and also when I tilt the sunroof only the left side will tilt but not the right. I've tested it using a different sunroof motor but that isn't the problem.. Any advice or some help? Thank you.
Old Apr 9, 2014 | 10:41 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
moved to maintanance sub sectio, please use the proper sub forum in the future.
I would start by checking the track for debris or see if the rubber is getting in the way or anything is frozen/locked.
skins990
Feb 12, 2025 03:26 PM
CrackerJac
Dec 23, 2023 08:53 PM
svt5150
Mar 29, 2023 08:10 PM
funcrusher
Jan 11, 2019 08:05 PM
amblyn
RX - 1st Gen (1999-2003)
Dec 5, 2011 06:49 PM
