Front Lip
Old Feb 2, 2003 | 07:45 PM
LEXO-400's Avatar
LEXO-400
Default Front Lip
small minor cosmetical problem, the bottom front lip is not fully contoured to the shape it potudes out in the middle i see it on allot of sc's any way of fixing it up?
Old Feb 2, 2003 | 08:30 PM
awj's Avatar
awj
Bluegr*** Performance
The one on my car is protruding as it rounds the ends on the driver and passenger side. I'm thinking it would be a fairly easy fix to get under there and loosen the bolts/nuts holding this piece in place and repositioning the lip. Having someone hold it in position while tightening the fasteners back down.
Old Feb 2, 2003 | 08:56 PM
LEXO-400's Avatar
LEXO-400
How does a heat gun sound?
Old Feb 2, 2003 | 09:19 PM
awj's Avatar
awj
Maybe we are thinking of two different problems. Are you referring to a warped or physically deformed lip? Mine is merely out of position I think. Pictures will help but it is too late for me to make any now. Maybe tomorrow. I would strongly suggest not using a heat gun - but if you want to try it - more power to you. If it is warped you will probably have to bite it and find a new one or a used one to replace it. If you really want it to look right.
Old Feb 2, 2003 | 10:05 PM
Phoenix88's Avatar
Phoenix88
Hey if you do attempt to work on the lip, please post some how to pics if you can. It will help the board a lot. Although I most likely wouldn't fix it myself, mine has a small crack and is slightly deformed like yours is.
Old Feb 2, 2003 | 11:47 PM
bizzy928's Avatar
bizzy928
Mine is warped. Is it true that if you replace the lip you have to replace the underengine protection plastic piece as well?
Old Feb 3, 2003 | 04:52 AM
sxylxy's Avatar
sxylxy
I tried hot water, didn't do much for the long term. Perhaps someone's willing to try a heat gun?
Old Feb 3, 2003 | 07:14 AM
awj's Avatar
awj
I don't see why. But it is possible. I will follow up.
Old Feb 3, 2003 | 08:19 AM
skininja's Avatar
skininja
I have tried the heat gun method - depending on how warped your lip is, it should do the trick. Once that plastic gets hot, it is very workable. Just be careful not to over-do it ....
Old Feb 7, 2003 | 02:40 PM
mjames08's Avatar
mjames08
I just removed my front lip.. It doesn't look like you would have to replace the under engine plastic if you got a new lip.. It just screws onto the lip..
Agonciulea
Sep 22, 2014 06:59 PM
SPKV6
Sep 10, 2010 09:24 PM
BoostenSC4
Sep 7, 2006 08:10 AM
