Oil Pressure Light on Startup
Old Mar 20, 2013 | 11:06 PM
eknine9's Avatar
eknine9
Default Oil Pressure Light on Startup
Just wondering if it's normal for the oil pressure light to come on for a second upon start-up. Always thought it was normal, but at the same time I'm a little worried that something may be going on, on really cold starts I get a slightly rough sound upon startup. TheAzn had a similar problem in a thread a while back and was told that he had slightly low oil pressure upon startup and it was nothing to worry about.
But I can't help but worry about it. Any common causes for low oil pressure upon startup with the 2jz, anything I could do to fix this? Anyone else had similar problems with their oil pressure?
Old Mar 21, 2013 | 07:22 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
run 5w30 in the winter and make sure your level is full.
Old Mar 21, 2013 | 01:49 PM
Jos's Avatar
Jos
My thread above yours about losing two quarts of oil in day is kinda the same thing, the light alerted me and when I checked I was low a quart and half. I'd double check everything especially during winter.
Old Mar 21, 2013 | 02:52 PM
eknine9's Avatar
eknine9
My oil level is fine, It's been 80-90 or so degrees here for the past 2 and a half weeks here in Texas.
My oil pressure light has flashed on at start since I've owned the car, I always thought it was normal with this car as it's never had any problems. My oil level light has never come on, so I don't think it's the same problem as I'm not losing oil.
Old Mar 21, 2013 | 04:53 PM
TheAzn's Avatar
TheAzn
Yea, the shop I took it to told me it's nothing to worry about. The causes could be dirty oil jackets/ plumbing, oil pump. I asked if I should replace the oil pump but they said no.
I've thought about trying Seafoam or other cleaners but I'm afraid it'll bring out a leak or something.
Old Mar 22, 2013 | 07:34 PM
Vrank's Avatar
Vrank
at 267k plus miles it's probably a good idea to start replacing things like the oil pump if you're trying to avoid a complete rebuild...
Old Mar 22, 2013 | 08:30 PM
2jznosht's Avatar
2jznosht
how long does the light stay on? are we talking its gone whn the other dummy lights go off, or does it linger?
Old Mar 22, 2013 | 08:31 PM
StiCk3's Avatar
StiCk3
my 1J does the same thing, oil light seems to linger for a little longer than usual on start up (working on cars all day, they usually go off right when it starts up). Only two things i can think of are a worn oil pump or worn bearings causing reduced oil pressure. it does bother me a bit, but like you it doesn't come on while driving and im not leaking any so im not terribly concerned
Old Mar 22, 2013 | 10:14 PM
eknine9's Avatar
eknine9
It's maybe a couple tenths of a second longer than the other dummy lights.
Hoping it's not worn bearings at 148k miles
Old Mar 23, 2013 | 04:59 AM
TheAzn's Avatar
TheAzn
Same here, does not stay on. Only stay on a hair of a second longer when all other lights go off, occasionally it may go out before another light.
Old Apr 10, 2015 | 04:00 PM
eknine9's Avatar
eknine9
Any new viewpoints on this issue?
Nothing bad has happened to my car, however the oil pressure light stays on for a full second longer than the other lights now. Don't know if impending doom is approaching or if everything is still fine.
Old Jul 29, 2025 | 09:06 AM
is350hopeful's Avatar
is350hopeful
What ended up happening? Been having the same issue on mine for some time now. Knowing the end result of yours would be very helpful. Thanks
Vil3x
15
Jan 13, 2020 11:51 PM
lexaus
27
Feb 25, 2019 04:12 AM
DJohns17
Nov 29, 2011 10:23 PM
InhumaneSC
Apr 18, 2010 12:36 AM
Jackal
Jan 1, 2007 04:25 PM
