Highest gear ratio?
Old Dec 3, 2012 | 06:29 AM
FastCarsBG's Avatar
FastCarsBG
Default Highest gear ratio?
So for my 92 SC I am looking for the highest gear ratio possible. The car is going to be a Bonneville car and the record is 224. I can (and probably should) swap in a 9 in rear end but don't want to do the live axle thing. Does anyone know if there is a taller gear than the mkiv manual TT set up? (3:13 or 3:17 or something like that)
Old Dec 3, 2012 | 10:00 PM
KahnBB6's Avatar
KahnBB6
For the 220mm TT 6-speed diff you should only have 3.133:1 as the lowest. There were other 220mm ratios offered in other markets but that should be the lowest.
For the more common 200mm rear diff I believe 3.266:1 is the lowest.
If there were other, lower ratios I am not aware of them as far as the US market cars are concerned.
Old Dec 4, 2012 | 08:24 AM
Jostar's Avatar
Jostar
3.26 JDM ring & pinion will take you to 250MPH if you are a 6 speed in 5th gear at 9.5k-10k RPM's...
What Trans are you going to run?
Crusher103
Feb 5, 2016 02:48 PM
andrewshu3
Performance
Jun 14, 2010 06:53 AM
WAR Inc.
May 6, 2008 05:54 PM
Sined7
Performance
Mar 24, 2007 05:54 PM
ISC400
Jun 13, 2006 01:04 PM
