Overheating
Old Aug 25, 2012 | 09:41 AM
eknine9's Avatar
eknine9
Default Overheating
Guys, quick question. Car is overheating and I've checked a few things, but am wondering what certain symptoms would be for specific parts of the car that would cause overheating.
In my last car when the water pump goes out there'd be a little leak around the lip of it, when the water pump goes out on this car, what kind of symptoms would there be? What about the radiator? The engine fan is working properly, and there aren't any obvious or major leaks under the car and I haven't found any coolant leaks either.
Coolant level is topped off and oil level is also fine.
Could the thermostat be stuck open? Would that cause overheating?
Are there any other things I could be overlooking here?
1992 SC300 5speed
Old Aug 25, 2012 | 09:46 AM
ihiryu's Avatar
ihiryu
It would be stuck closed.
When the car is at operating temp, check the lower radiator hose and see if it's hot. If it's cooler than the top hose, then you've got a stuck radiator.
What part of texas are ya at?
Old Aug 25, 2012 | 09:51 AM
eknine9's Avatar
eknine9
I'm up in Lubbock for school.
The car has been off for about 5 minutes, and the lower hose is way cooler than the upper hose. So this means I'm going to need an entire new radiator? Are there any good vendors to buy a radiator from online?
Old Aug 25, 2012 | 10:24 AM
scmaluco's Avatar
scmaluco
before you start spending money try flushing it first and go from there..
Old Aug 25, 2012 | 10:31 AM
eknine9's Avatar
eknine9
Won't I have to leave the engine running while the flush liquid is in the radiator? The car overheats before too long. Will I be able to flush it properly, or are you suggesting just a drain and refill?
Old Aug 25, 2012 | 11:02 AM
ihiryu's Avatar
ihiryu
You need it to run a bit longer than that bro. Five minutes is definitely not enough.
Old Aug 25, 2012 | 11:14 AM
eknine9's Avatar
eknine9
The car was past normal operating temperature when I turned it off, just short of the red bar according to the gauge. It had been off for 5 minutes when I touched the hoses to check temperature.
Old Aug 26, 2012 | 12:23 AM
ihiryu's Avatar
ihiryu
Yup well seems like we've got a winner.
Old Aug 26, 2012 | 09:24 AM
scmaluco's Avatar
scmaluco
i would recommend flushing it with a hose.. engine off. disconnect both hoses and flush it out connect everything top it off with water and let it warm up. then repeat the process . see if it helps.. you should be able to see how much water is flowing out thru the bottom and if there any gunk or what not coming out...
Old Aug 26, 2012 | 03:01 PM
soarer13oy's Avatar
soarer13oy
Just stick a water hose on the upper radiator and run water through the radiator. Make sure you remove the lower radiator hose to see if it flows well.
Dupshaw123
IS F (2008-2014)
Jul 2, 2019 10:50 PM
lanthern22
GS - 1st Gen (1993-1997)
Jan 6, 2010 08:31 AM
madmax98
May 13, 2008 10:18 PM
Lexus082
Nov 27, 2007 01:31 PM
ztikmedia
Sep 1, 2003 01:59 AM
