95 sc400 Alternator
Old Jul 22, 2012 | 07:39 AM
booramey's Avatar
booramey
Default 95 sc400 Alternator
I have a 95 sc400. I took it yesterday and had new rear speakers installed at a shop.On my way home the stereo qu[t working then the ABS -Trac -control-and battery lights came on the dash. I stopped and shut the car off and it would not even try to start.Checked the battery and only had 7 volts. Put a new battery in and drove it home . Took it this morning and had it tested and was told alternator is bad.Any connection? thanks
Old Jul 22, 2012 | 09:30 AM
OG Dada's Avatar
OG Dada
Any oil leaks? I just went through this just a week ago...
Old Jul 22, 2012 | 10:07 AM
booramey's Avatar
booramey
No leaks. Why?
Old Jul 22, 2012 | 10:53 AM
OG Dada's Avatar
OG Dada
Might be just a old weak alt then...
Old Jul 22, 2012 | 11:25 AM
xspsi6's Avatar
xspsi6
9 times out of 10 the ps pump on these sc400's leak and destroy the alternators so as kingphilip said be 100% sure it's not leaking even just a little bit. but either contact aliga on here to buy a good used one or just rebuild it your self which there is a diy on here and it's super easy which is what I did for my sc400.
Old Jul 30, 2012 | 06:16 PM
booramey's Avatar
booramey
Default still having problems
put a new alternator on and drov eit for a couple hours then the trac. control and check engine light came on , any ideas?
Old Jul 31, 2012 | 03:57 AM
booramey's Avatar
booramey
Thumbs down thanks so much
thanks for all the help
Old Jul 31, 2012 | 03:57 PM
over40driv's Avatar
over40driv
If it is your alt. the ALT light or pic. of a square red battery light would be on, not the CEL. That warning light is on the right hand side of the steering column on the dash.
JDMlife
Aug 31, 2015 10:59 AM
suprarale
Jan 8, 2014 02:49 AM
BOBSOFI
Dec 9, 2008 03:12 PM
SC4Hundred
Feb 10, 2005 02:49 AM
