i have a 93 sc300 NA-T and i just did a 5speed swap with a w58...everything is installed and pulls fine BUT it has a very bad bump sound coming from the center where the shifter is...I know its the drive shift but i dont know why..the trans mount seems to be fine and center shift mount also...And when i say bump,i mean BUMP,Its like the whole car is shaking and going to fall apart...The more RPMs the worse it is..
If you ever noticed a small couple of square things on your driveshaft, those are weights. Think of your driveshaft as a wheel needing a balance. If you do not install it a certain way it will be out of balance. They either are welded or stickied on sometimes they fall off.
Ok guys just to let you know..the drive shaft thing was my fault for rushing to get it together....if you know at the end of the drive shaft there is a rubber donut with 6 holes......lol i was only using 3 of them holes...so i had it thru the drive shaft and st8 to the diff......lol as soon as i jacked it up i was like ****...lol but thanks for the help guys..close thread plz
