Help!!!!! car stopped while driving...
Old Apr 29, 2012 | 07:17 PM
supraclay's Avatar
supraclay
Default Help!!!!! car stopped while driving...
I was leaving work and didnt even make it out the parking lot. my car just turned off. it turns over so i know its not locked up, it has fuel pressure.... i think it might be something with my ignition system but not sure.... anybody have any ideas???????
Old Apr 29, 2012 | 07:29 PM
/Aerostar\'s Avatar
/Aerostar\
Ignition pack maybe (the thing that the lead from the distributor runs to)
Alternator (use jumpers to another car and see if she runs)
Something funky with the throttle body (does the butterfly rotate freely?)
Vacuum lines
Good luck
Old Apr 29, 2012 | 08:15 PM
Tabaka's Avatar
Tabaka
When the car shut off you probably got a CEL correct? Run a code scanner and see if something pops up. I had the same thing happen to me last year and it ended up being the MAF/AFM.
Old Apr 29, 2012 | 11:17 PM
GS4_Fiend's Avatar
GS4_Fiend
There are too many variables. You need to check out the basic first and let us know what information you have gather, then we can help you efficiently.
Old May 1, 2012 | 03:55 PM
supraclay's Avatar
supraclay
Ok i have fuel pressure, spark timing still good still don't know Wat could be wrong i doubt its my Maf but who knows ill see if i can find a scanner and check for codes?
Old May 1, 2012 | 08:22 PM
GS4_Fiend's Avatar
GS4_Fiend
I would check battery connections, make sure charging system is good. Make sure battery is good. Have you tried the 12V fuel pump mod yet?
Old May 1, 2012 | 08:24 PM
supraclay's Avatar
supraclay
ok correction i dnt have fuel pressure and i dnt have power to my fuel relay or the pump i can bypass the relay by running straight power to the pump but not really a good idea..... any suggestions or ideas why im not getting power to the pump?
Old May 1, 2012 | 09:11 PM
GS4_Fiend's Avatar
GS4_Fiend
You don't have power to the Fuel pump relay? Did you check the EFI fuse? Have you tried switching relays?
Old May 1, 2012 | 10:07 PM
INTIMAZY's Avatar
INTIMAZY
Fuse, fuel ECU, or fuel pump.
Old May 2, 2012 | 09:03 AM
Tabaka's Avatar
Tabaka
ah yes, the fuel pump ECU. Forgot about the time it left me stranded lol.
GJoe
Mar 30, 2019 04:58 AM
jporchia
Oct 29, 2013 08:29 PM
AM21GS400
May 30, 2013 08:45 PM
incharlest
Apr 20, 2013 09:55 AM
toy4life86
Apr 18, 2012 11:36 AM
