Need help
Old Mar 29, 2019 | 01:46 AM
GJoe's Avatar
GJoe
Default Need help
I have a gs300 1998 and i had a code p0171 so i changed maf sensor and it went away now i have a new code p0304 so i checked the cylinder 4 spark plug and changed them all code went away no check engine light but car won't drive loses power in idle the codestill pops up even though the check engine light is not on
Old Mar 29, 2019 | 06:04 AM
TrueGS300's Avatar
TrueGS300
Maybe there is an actual vacuum leak. This will cause misfires. Most cars I work on don't need the MAF replaced when a lean code pops up.
Old Mar 29, 2019 | 11:44 AM
GJoe's Avatar
GJoe
Alright thanks i will double check everything
Old Mar 30, 2019 | 04:58 AM
TrueGS300's Avatar
TrueGS300
Clean the throttle out and check for vacuum leaks. Make sure the pcv valve is fully seated, no cracked or damaged hoses. Listen for hissing noises. Use a vacuum gauge if available, or a scan tool to check for lean fuel trims.
zaruss918
May 12, 2016 11:33 AM
unlex
Nov 22, 2014 07:29 PM
Larry62
RX - 1st Gen (1999-2003)
18
Mar 18, 2013 01:45 PM
GS300noob
Apr 6, 2012 11:51 AM
nismo2trd
Mar 19, 2007 06:40 PM
