mk3 supra injector resistors???
so there was a n/a supra at the junkyard yesterday. and i snagged what appeared to be 2 resistor looking boxes.
i have jdm 444's. but i will prob want to run mk4 usdm injectors in the future. so iam wondering does anyone have the p/n for the actuall injector resistors for the 7m??
also are they only on the turbo or are they also on the n/a??
in my experience injector resistor box's doesn't matter what car it is off of. low impedence is simply low impedence. I am running low impedance injectors 850cc and I am using a mk3 tt supra resistor box.
I know people that just grab whatever resistor box from any car, splice the wires and feed it in. all that is done is it changes the power to the injector. someone correct me if i am wrong but in my view the injector has 2 wires (1 constant power, 2 is signal wire from ecu). so all you are doing with the resistor is modifying the electric current to the injector which there are 2 standards, high and low. so any low impedance system will work the only differences are the number of cylinders.
