450cc injectors out of eclipse, yes or no
will the 450cc injectors work on a na sc300? i know i would need the wire harness adapters, they look the same shape. i just do not know if they are high or low imp. anyone know?building a budget turbo setup and have 12 of these injectors laying around. thanks!
Turbo models have low impedance injectors (2-3 ohms), and include a resistor pack in the electrical system. Non-turbo models (including the Spyder 2.4L) have high impedance injectors (13-16 ohms) and do not have a resistor pack.
Originally Posted by Junk
are the na injectors high or low? is there a way to install the resistor pack?
Resistor pack is instad of using resistors to switch impeadences for the injector driver. It should only be 2-3 wires.
LEXO400sc
Nov 20, 2003 09:20 PM
