92 engine harness for SC3 in a 95 SC3 will it work?
Old Apr 21, 2012 | 05:32 AM
jdmkiddd's Avatar
jdmkiddd
Default 92 engine harness for SC3 in a 95 SC3 will it work?
ok guys like stated above will it work ? i took the intake and everything apart the other day to get to the injectors and in the process i broke the tps sensor clip and all 6 injector clips also another clip on the side of the intake i would like to know if the engine harness from a 92 2JZ-GE will fit my 95 2JZ-GE?? because i found a guy selling one on ebay for $60 which is by far the cheapest I've found. .. also i was thinking that if the harness wasn't direct plug and play , i was going to just salvage the clips that i need from the 92 harness. i would of course take my time and solder everything together and heat shrink everything in east to get to places just in case anything were to happen so i would also like opinions on that. i already know some of you are not gunna like the idea but ill take any feedback. thanks a lot guys
Old Apr 21, 2012 | 07:24 AM
jdmkiddd's Avatar
jdmkiddd
anyone??
Old Apr 21, 2012 | 07:29 AM
trancuongv's Avatar
trancuongv
Originally Posted by jdmkiddd
anyone??
It will work, just a few plugs that needs modifing if you trying to use the whole entire harness. The alternator plug is different from 92-95. But seems like you just need other plugs that's not related to that. Good luck.
Old Apr 21, 2012 | 07:47 AM
jdmkiddd's Avatar
jdmkiddd
thank you kind sir i appreciate this VERY MUCH!!
Old Apr 21, 2012 | 09:11 AM
93MSB's Avatar
93MSB
there is a difference in the harnesses, you will have swap a wire or two on the body plugs, because there is a difference in the starter wiring. also the 95 cars have the alternator wiring in the body harness whereas the 92-94 is in the engine harness.
i think its going to be more trouble than you want to get into, if I were you I would just replace the clips on your original harness. each clip has a 5 or 6 digit number on it, you should be able to get them from Toyota or Lexus just give them the number
Old Apr 21, 2012 | 09:29 AM
99SC42's Avatar
99SC42
Do what this^^^ Guy said. It will be less headache than trying to convert the 92 harness.
gl
Old Apr 21, 2012 | 10:10 AM
jdmkiddd's Avatar
jdmkiddd
how much do you think those clips cost each from toyota or lexus?
Old Apr 21, 2012 | 10:15 AM
99SC42's Avatar
99SC42
It will be cheaper buying them from toyota .
Old Apr 21, 2012 | 11:22 AM
93MSB's Avatar
93MSB
iirc they are around $5 a piece, and remeber if you need the wires (aka terminals) they are separate and are around $3-4
jkpgt96
Jul 16, 2015 08:01 AM
ippyness
SC400 / 300 Classifieds
Mar 21, 2008 10:43 AM
