1.5jz help max boost?
Old Apr 10, 2012 | 03:42 AM
Nishihara's Avatar
Nishihara
Default 1.5jz help max boost?
Im running a 1.5 jz swap with my stock ge block with a 1jz head and wanted to make more on the dyno how much boost can I run? I have a 255 fuel pump and 440 injectors. Apr head studs with a safc. I'm at 13psi now. Any info would help a lot thanks.
Old Apr 10, 2012 | 05:02 AM
spoolxexo's Avatar
spoolxexo
You are in Cali, which means you only have 91 octane at the pump.
This limits you quite a bit.
The boost you "Can" make is relative to:
-Static compression ratio of the engine
-Total timing at WOT
-Fuel setup
-How much boost the turbo(s) can physically make.
You didn't mention what turbo setup you are running!
In your case you are capped at:
-Fuel system is good for around 420HP to the wheels
-You can make around 16-18 degrees timing safely on 91 octane
-The Stock ECU has a boost cut function, so either way you can only get to 18 psi before it cuts fuel off.
Old Apr 10, 2012 | 05:09 AM
99SC42's Avatar
99SC42
^^^You beat me to it.
edited
Old Apr 10, 2012 | 05:23 AM
spoolxexo's Avatar
spoolxexo
Sorry bud, I get all excited when tuning talk is going on!
Old Apr 10, 2012 | 06:02 AM
99SC42's Avatar
99SC42
No problem haha!
Old Apr 10, 2012 | 10:15 AM
Nishihara's Avatar
Nishihara
Nice. Thanks guys that's what I wanted to hear I'm running stock ct12's and 18 psi is the max I wanted to run lol.
Old Apr 16, 2012 | 12:54 AM
Nishihara's Avatar
Nishihara
You guys think I made good power I hit 307hp and 325tq on stock boost well 13psi because of my down pipe I guess.
Old Apr 16, 2012 | 05:46 AM
INTIMAZY's Avatar
INTIMAZY
Sounds right on target. You are on the verge of boost cut anyway unless you have a way to defeat it.
With my downpipe, I would regularly hit boost cut in high gears if it was less than ~60 degrees outside. The slightest airflow mods could put you over the edge so you will need to find a way around boost cut.
Not sure how much more headroom you gave yourself with 440's
Old Apr 16, 2012 | 06:12 AM
Biggu's Avatar
Biggu
my 1jz running AEM ems, stock downpipe and cat back ehxaust made 398/379 TQ at 17psi.
deputy865
Mar 25, 2014 02:24 PM
s1984
Mar 28, 2013 07:25 PM
LexCafe
Performance
28
Feb 9, 2012 03:29 PM
antonio356
Dec 12, 2011 01:33 PM
stockhatch
Oct 20, 2010 06:21 AM
