Ps pump question
Old Jan 25, 2012 | 08:40 AM
Farino81's Avatar
Farino81
Default Ps pump question
I have a sc400 and every morning when i start the car i hear this buzzing noise coming from the ps pump and then after it warms up it stops. I know this usually means the pump is going bad, has anyone had this same problem?
Old Jan 25, 2012 | 09:12 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
probably has some air in the system. you can try bleeding it.
basically lift up the front wheels top off the reservoir and keep turning it from left to right.
it will not work with the wheels on the ground. if that fails you may need a new reservoir or pump.
Old Jan 25, 2012 | 09:21 AM
8kpsshh's Avatar
8kpsshh
I had a similar experience with that sound.... When I bout my car I replaced the PS pump with an autozone one.... (I used power steering fluid..... OOOooops). I was suppose to use Transmission fluid.... I swapped out the fluids and bled the system too many times to count.... never seemed to remedy the problem. I ended up taking the pump back and getting another one except this time I used Transmission fluid from the start... It's been fine since then.
Old Jan 25, 2012 | 09:22 AM
Farino81's Avatar
Farino81
are acdelco pumps any good? what brand do you recommend?
Old Jan 25, 2012 | 09:31 AM
Tabaka's Avatar
Tabaka
AC Delco is fine but try bleeding yours first. Sometimes it's the solenoid in the rack that needs cleaning or replacing. Do a search and you'll come across that DIY thread.
Old Jan 25, 2012 | 09:48 AM
Farino81's Avatar
Farino81
pump is leaking
Old Jan 25, 2012 | 09:54 AM
Farino81's Avatar
Farino81
is this one okay?
http://www.ebay.com/itm/260825359258...ht_1245wt_1139
Old Jan 25, 2012 | 11:06 AM
Farino81's Avatar
Farino81
any suggestions on which pump to get?
Old Jan 25, 2012 | 11:46 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Maintenance and engine related question moved to maintenance.
Old Jan 25, 2012 | 01:05 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
OEM or Denso
Old Jan 25, 2012 | 01:13 PM
Farino81's Avatar
Farino81
denso? i dont think they even make a pump. i just searched and all i see is a1cardone and acdelco
Old Jan 25, 2012 | 03:52 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I thought the OEM was denso, might be wrong on that one, so basically I am saying I would recommend OEM.
both the ones you listed are aftermarket, they would probably work well, maybe choose based on warranty.
Dave_G
May 17, 2015 08:38 PM
dcre27
Jan 19, 2015 06:11 AM
Dx3
Jun 25, 2014 11:47 AM
MyGS3
GS - 1st Gen (1993-1997)
14
Mar 4, 2014 09:00 PM
worldforgo
Feb 4, 2012 09:47 PM
