starting problems. will crank but no start
Old Jan 18, 2012 | 07:44 AM
marty9974's Avatar
marty9974
Angry starting problems. will crank but no start
I have changed the fuel pump,time belt, and water pump. my check engine light does not come on I beleive that its one of my sensors because they dont always give off codes when they do go wrong. If someone has had the same problem please give some advice I will give you more details.
Old Jan 18, 2012 | 09:34 AM
xxtoobsxx's Avatar
xxtoobsxx
need more info...what engine you have etc...
Old Jan 20, 2012 | 05:52 PM
marty9974's Avatar
marty9974
I have the 1uz v8.
Old Jan 20, 2012 | 05:53 PM
marty9974's Avatar
marty9974
i have the 1uz v8. its a 1992 sc400 with just about 140,000 on it. if you need any more info just let me know
Old Jan 20, 2012 | 08:43 PM
k7q's Avatar
k7q
wrong timing?
Old Jan 20, 2012 | 08:51 PM
Vwpride12's Avatar
Vwpride12
Narrow it down. Spark, fuel, and air. Needs all three, your missing one or two.
Old Jan 20, 2012 | 09:43 PM
marty9974's Avatar
marty9974
It will only start sometimes, I cant turn it off and turn it back on sometimes i can but not that often i would have to give it some time. it seems like an electrical problem(its not the starter, battery, or alternator dont insult me).
Old Jan 20, 2012 | 09:48 PM
marty9974's Avatar
marty9974
whats up?
i dont think its the timing its a bad connection some where or a sensor.
i have just been trying to eliminate possibilities
Old Jan 20, 2012 | 11:18 PM
mdmaniac's Avatar
mdmaniac
There are millions of reasons that a car would crank but not start. The two most likely are a) Distributor is 180 degrees out and b) fuel filter is clogged. Marty, how about you run us through your diagnostic process so far and maybe we can identify something you've missed?
Old Feb 23, 2012 | 05:22 PM
marty9974's Avatar
marty9974
Default No more start issues
It turned out to be my ECU and also a bad crank sensor but all i did was cvhange the ecu and it work out fined.
Old Feb 23, 2012 | 07:29 PM
jtamulis's Avatar
jtamulis
A bad ECU? wow.
Old Mar 3, 2012 | 02:08 PM
marty9974's Avatar
marty9974
where does the lexus club meet in northern virginia. i always see the z guys and a couple of others but never lexus.
Old Mar 4, 2012 | 01:01 AM
xxtoobsxx's Avatar
xxtoobsxx
I was gonna suggest bad ecu once. Happened to me, sold the car. Then it happened to another guy I know, I said lets try swapping ecu's. Boom started up and I cried for selling mine. Lol
Old Mar 6, 2012 | 08:55 AM
WadeLovell's Avatar
WadeLovell
Crumbs! Really hoping mine is something else.
Old Mar 7, 2012 | 11:17 AM
xxtoobsxx's Avatar
xxtoobsxx
what is your car doing?
whitman
RX - 1st Gen (1999-2003)
Jul 8, 2016 01:02 PM
Adam91
Feb 6, 2016 10:30 AM
mehall
18
Jul 1, 2013 05:03 PM
zero44
GS - 1st Gen (1993-1997)
Oct 12, 2010 01:03 AM
clean4dr
Maintenance
Dec 14, 2009 02:51 PM
