Started head gasket job..
Old Dec 29, 2011 | 11:26 PM
ISFFUN's Avatar
ISFFUN
Default Started head gasket job..added pics
Took about 5 hours but we got the upper intake manifold and stuff off. The hardest part was getting the manifold to come out of the rear bolt.. there's a stud that holds that wire loom on and the vacuum lines are UNDER the manifold so we were yanking for like an hour getting frustrated until we figured it out.
Timing belt was done around 80K and at 130K there's some separation and cracking. New belt from Carson Toyota was about $25 or $30 ish.
This is not a fun job..but still better than paying $1,500 or something for a shop to do it.
I'm not looking forward to tomorrow..ugh
Anyone know if you HAVE to pull the crank pulley ? (answer: to take the head off - NO)
Old Dec 30, 2011 | 11:32 AM
nivek5sfe's Avatar
nivek5sfe
if youre replacing the timing belt also ,as it sounds like you are, then yes you do have to pull the crank pulley.
Old Dec 31, 2011 | 09:33 AM
ISFFUN's Avatar
ISFFUN
Wow, after another 6-7 hours yesterday we got the head off but we're stuck on the crank bolt. Wow,there's two of us with 5ft breaker bar..we tried an acetylene torch and oil to heat up the bolt..tried the starter trick. nothing worked so far.
I need to replace it but can't! LOL. We don't havea chain wrench either.
Old Dec 31, 2011 | 09:36 AM
GSteg's Avatar
GSteg
Time to fit the largest 3/4" or 1" impact gun you can find!
Old Dec 31, 2011 | 09:43 AM
ISFFUN's Avatar
ISFFUN
You remove the bolt like a standanrd counter clockwise motion right?
Old Dec 31, 2011 | 10:08 AM
ISFFUN's Avatar
ISFFUN
We tried a 1/2 impact..no luck.
Old Dec 31, 2011 | 10:22 AM
ISFFUN's Avatar
ISFFUN
BTW Here was the leaking head gasket culprit . #6 cylinder (furthest in the back..)
Old Dec 31, 2011 | 11:01 AM
LEX_MAN's Avatar
LEX_MAN
Tried the old starter trick? Remove the efi fuse, breaker bar on the ground and crank the engine?
Or is it too late for that.
Old Dec 31, 2011 | 11:47 AM
nivek5sfe's Avatar
nivek5sfe
do this. this is how i always remove my crank bolt. mine is a stick shift so its a tad easier to bump.
Old Dec 31, 2011 | 02:45 PM
bighead222's Avatar
bighead222
Default northern tools my friend.
had the same pro with my gs broke many breaker bars.. go to northen tools and they have a huge braker bar and its up to 1000 lbs used it once and it worked returend it after with no pro
Old Dec 31, 2011 | 06:02 PM
ISFFUN's Avatar
ISFFUN
Finally got it off with a 3/4 drive breaker bar and more heat from the acetylene and a chain wrench. Whew.
NOT looking forward to putting the head bad on..gotta wait until Monday for the shop to open to get the head checked and cleaned. There are so many lines and wires..
Btw we tried the starter breaker bar on the ground and it didn't work.
Thx for the input all!
Old Jan 2, 2012 | 09:52 PM
ISFFUN's Avatar
ISFFUN
Holy ****. Finished around 9PM. Started thursday afternoon, worked every day until today. In total it was about 25 hours with two of us taking time to figure out stuff and clean and prep new parts., putting stuff on in the wrong order then having to take it off again..that kind of stuff.
I read somewhere that the HG on our cars always breaks near the rear and mine was the furthest (#6?) cylinder. I wonder if it has anything to do with the lack of air back there or the EGR cooling chamber..
I'll post some more stuff up later about the job.
OH - problems- 2 hoses not connected and no heater.
Old Jan 2, 2012 | 11:17 PM
pieisgude's Avatar
pieisgude
Lol, sounds like you had fun. Better than paying a shop to do it.
Old Jan 3, 2012 | 04:18 PM
dwebb99's Avatar
dwebb99
BTW , SCHLEY Crank Remvoal tool #64300 from Amazon ($60) is a GREAT TOOL for removing Lexus Toyota Crank Pully's. You will still need cheater bars(2) and 6 sided 1/2" drive impact socket for crank bolt (Harbor Freight/Northern Tool...$10 each(go 1/2" drive). And a jack handle over the cheater bar. It sure helps to also have a 300 lb football linebacker to pull on the 4 ft cheater bar! It sure get's the job done though!!
Old Jan 3, 2012 | 04:37 PM
ISFFUN's Avatar
ISFFUN
Here's a picture of the #6 cylinder
