Brake light delay
Old Oct 9, 2002 | 05:40 PM
VSsc400's Avatar
VSsc400
Default Brake light delay
I noticed when I step on the brake gentle enough to be slowing down the brake lights don't light up until I press a little bit further. I'm not sure if this is the way its supposed to be.... Is there any way to make it more sensitive?
thanks
Old Oct 10, 2002 | 03:41 AM
asfaltsurfer1's Avatar
asfaltsurfer1
look under the dash at the brake pedal, now follow the bar that the pedal is mounted on under the dash. You will notice a blue switch with a red button (colors may very depending on model) that comes in contact with the pedal arm. This switch has two nuts on each side of it's mounting bracket, I think there about 12mm??. If you back off the nut that is toward the rear of the car 1/2 turn then tighten the other nut this may work, if not repeat the last step 1/2 turn at a time untill the light illuminates to your liking. Hope this helps, if not PM me and I will give you a SOBER explanation.
Old Oct 10, 2002 | 04:15 AM
asfaltsurfer1
Old Oct 10, 2002 | 02:15 PM
VSsc400's Avatar
VSsc400
i'll try that tomorrow night.
salomon
IS - 1st Gen (2001-2005)
Jun 25, 2018 01:33 AM
sktn77a
RX - 1st Gen (1999-2003)
May 31, 2016 01:04 PM
pvong713
Jun 29, 2013 06:54 AM
flyfl1pguy
May 21, 2011 06:09 PM
BamPearl
Feb 9, 2010 02:52 PM
