92 rear lower control arm??
Old Nov 19, 2011 | 09:08 AM
myrmidon's Avatar
myrmidon
Default 92 rear lower control arm??
Hey dudes,
What is this part actually called? I've been searching around for awhile, and while taking off my knuckle to replace the wheel bearing I managed to completely mangle the ball joint boot, so I would like to replace it.
It's the part that has the strut/swaybar bolted to it.
Thanks!
Old Nov 23, 2011 | 03:10 PM
topdog849's Avatar
topdog849
lower control arm....???
Old Nov 23, 2011 | 03:18 PM
CrazySC300's Avatar
CrazySC300
What Topdog said! ^^^ But yeah, If you're gonna change out the rear lower control arms, You might as well go with aftermarket adjustable ones like what I did...
Old Nov 23, 2011 | 03:46 PM
ArodDaLob's Avatar
ArodDaLob
iirc, if it's just the boot that you f___ed up, i think you can replace that from something from summitracing. do some more research, but i think someone on here found a replacement for control arm ball joint boots.
Old Nov 23, 2011 | 07:52 PM
topdog849's Avatar
topdog849
I need new lower control arms sense my camber bolt is seized up to the bushings, what are the price on those pretty blue LCAs? and where do I find?
Old Nov 23, 2011 | 08:06 PM
xspsi6's Avatar
xspsi6
Who makes those blue ones? Not the Megans.
Old Nov 23, 2011 | 09:47 PM
OG Dada's Avatar
OG Dada
Eau Rouge, Japan.
Old Nov 26, 2011 | 10:27 PM
myrmidon's Avatar
myrmidon
I'm actually pretty worried about the ball joint itself. I absolutely maxed out a impact fork for balljoints on it, and I think I started to physically pull out the ball joint from the arm.
SJ408sgmIS
Suspension and Brakes
Jul 5, 2012 09:08 AM
Clear2Cloz
Nov 4, 2011 09:04 AM
brit_lex
Jun 24, 2004 05:11 AM
