Compression test
1. Is it safe to battery crank the engine with TB off or do I need to hand crank compression test?
2. Whats an acceptable drop from high to low compression between cylinders?
3. Any easy way to clean valve, injector deposits w/o removing head?
4. Motor was noisy at shut down possible water pump but pump was inspected found good when overheating problem was resolved at 99K. Timing belt replaced at 89K. Figure I'll get it running on 6 (hopefully) before I can determine water pump failure or some other cause for noise. Any other possible cause of noise (pullys )other than water pump?
5. Anyone know of parts store that rents compression tester? Thanks for any reply.
I'm having a problem locating a heater hose, its the one at the back of the engine top behind #6 plug and behind and between the valve covers. Both Dayco and Gates have incomplete discriptions and the local part stores are somewhat mystified that the 3 bypass heater hoses in stock for the car are not the one I brought them. Lexus and Toyoya can't definatively give me a part # since the engine diagrams are vague so I can't order the hose with any degree of certainty. It's a molded hose and I'd perfer an OEM replacement . Anyone got a part # for this heater hose from Gates, Dayco Toyota or Lexus? Anyway got to get it backtogether soon as its getting cold in Massachusetts please respond NOW if you can help. Thanks Peter
Usually the service limit is 15 psi between cylinders warm, but it's a JZ engine. They are tough.
Also, for the love of god please split your paragraphs. They are incredibly hard to read.
Good luck.
Another solution to your deposits would be seafoaming the engine. There is a MASSIVE thread on this. read up!
-Cam
The hose was more trouble than it should have been it was out of stock in five local parts stores no in hand and 3 days wait, whats up? My local Toyota dealer coulden't find it on a Supra since apparently its a different setup with the heater valve. I had two ES's and accessing parts through Toyota is easier than on the SC.
I don't see how you could get a warm compression test even while only splitting the TB. I'm not that quick.
Anyway it's REALLY good to read that 15 lbs between cylinders is an acceptable reading on a cold engine,
I'll readup on Seafoam as I plan to change out the Fuel pump flush some old gas and get a fresh mix of high test + going.
What's my best option for door window gasket seal, the bottom strip where window drops, any help is appreciated got a leak and its raining.
Thanks Pete
Negatives were/are leaking bypass heater hose (Gates 19125), broken door handle passanger (clip) ebay, drivers door leaking window felt seal (serious rattle) and misplaced broken part left in door well (what were you thinking leaving a broken part in the door fella), broken antenna (motor good though) Radera ebay, smashed bumper cover replaced w/Jade OEM (almost perfect) off a 1992sc (Two Chiefs Carolina), broken head light (parts yard), dented left front fender (pulled), poor running engine (ongoing).
Positives sc300, excellant interior VERY CLEAN, no rust (little crud over windshield 6" though (eventual crop out w/new channel) before repaint, solid body, new timing belt @89K, new (used) transmission from "97" w/60K on it @110K, new radiator, head gasket, thermostat, cam-crank-waterpump seals coolant flush @99K, new starter @ 122K, new tires @111K, like new exhaust. Past owner put a LOT of money into this car in parts and repairs and probibly had CHECK BOOK FATIGUE hence parts car price and its yours take it away!!! My friends said the engine was shot no way its OK for the price. HAHA
My greatest fear after initial drive was the head repair was insufficient and returned then I was back to a rebuild. Anything short of that including water pump and timing belt and I'm happy. So far so good.
I thinks the plugs ,distributor/rotor, wires, fuel filter were all original. Replacing all with OEM Denso except Bosch fuel filter 1/3 the price of Denso. The TD was DEEP/DEEP in carbon and the EGR seriously clogged, the ROTOR I can't believe it was still running GO DENSO, holding on by a thread (literally) about 1/8 of an inch on the bar. Really 1/8" and still running YES the 2JZGE IS REALLY TOUGH.
As long as I can get ALL the vacuums line back in place I may be surprised and my time will be well rewarded. New high test and SEAFOAM. In any regard this car deserved a better fate than as a parts car. Only needed love and a 90K tune. YEHA lets get going. Times a waiting.
Thanks to all who have added to the library of threads that have helped me so far, its so much easier with access to Club Lexus to get the nuances of this car down so as to get the job done RIGHT!!!
Thanks Pete
Now the front end engine noise? At 89K timing belt was done I assume the water pump was replaced but I'll need to check with the garage. At 11/01/06 @ 98K an over heating problem was dectected. New thermostat, radiator, camshaft seal, crankshaft seal, waterpump gasket (water pump inspecked OK). Finally head gasket replaced and problem solved. My point is after water pump inspection and belt replacment so receint (miles wise) abiet in 11/01/06 only 33k miles but 5 years. Could the engine noise be something else or am I trying to look past the obvious.
Other possible causes fan assembley pully bearing, worn serpintine, timing belt tensioner. Any other possible causes? Those other solutions addressed then its time for WP and Belt. What's the best way to diagnose the root cause while excluding the good parts and not throwing money at the problem and replacing everything. HELP
Is there any way to know without physical inspection weather I've got a 10 or 11 nut water pump on a 2JZGE produed in 8/93? Also I know Aisin WP is OEM how about timing belt and tensioner what are quality and priced well?
Thanks Pete
