'97 SC400 Low Idle problem
Old Jul 9, 2011 | 02:59 PM
trademark's Avatar
trademark
Default '97 SC400 Low Idle problem
I just bought this car at an auction, check out low it idles! It sat for about 8 months, and I filled it up with 93 and drive it about 10 miles and it still idles so low. It runs pretty smoothly, although I think it could be a bit down on power. Any suggestions?
Old Jul 9, 2011 | 04:39 PM
scENFORCER's Avatar
scENFORCER
My '99 sc400 idles the same. As far as I know it's normal. But I've been meaning to ask the forum about it..
Old Jul 9, 2011 | 08:10 PM
SChumacher's Avatar
SChumacher
Mine its the same
Old Jul 10, 2011 | 01:18 AM
scE4's Avatar
scE4
Yeah.. mine does the same but the only thing my coolant temp gauge hit the H and i goes into limp mode.
Old Jul 10, 2011 | 01:25 AM
abounly's Avatar
abounly
Hmm, thats too low of an idle imo. Should be at least around 600-800. Mine use to do that, i believe it was my O2 sensor.
scE4. if you let your temp gauge hit H you pretty much blew your headgasket i would assume
Old Jul 10, 2011 | 10:34 AM
scE4's Avatar
scE4
I check the temp of the engine with a scan tool and its reading 72 c. It doesn't over heat. Just that my temp gauge hit the H then when I start to accelerate it will drop down to normal. I've replaced coolant temp sensor.
Old Jul 10, 2011 | 12:17 PM
trademark's Avatar
trademark
After driving the car around for a bit it seems to idle OK now. I think it just sat for a long time, about 8 months or so. I just found out its the 300 though, someone put the 400 badge on the back!!
Old Jul 10, 2011 | 12:32 PM
abounly's Avatar
abounly
^ so you never opened the hood?
Old Jul 10, 2011 | 12:50 PM
trademark's Avatar
trademark
No, I rushed in towards the end of the sale and didnt think to
Old Jul 13, 2011 | 08:45 PM
scENFORCER's Avatar
scENFORCER
^ WOW..
Anyways, anyone have any real answers to the low idle problem? Sometimes I worry my car is gonna stall out on me while at a red light. Obviously it never does, lol. But I'm curious to hear from other 400 owners, and what their idle is at.
Old Jul 14, 2011 | 07:00 AM
Tabaka's Avatar
Tabaka
Originally Posted by scENFORCER
^ WOW..
IACV probably. Same thing happens to mine everyday. Runs great for 15 minutes on my way to work, then I'll stop at a light and the RPM's will creep down to 500 or less sometimes shutting off. Turn your A/C or lights on, and it should raise back up. Either way clean your throttle body and IACV. Someone else mentioned it could be a vacuum leak.
Old Jul 14, 2011 | 01:49 PM
flux702's Avatar
flux702
Mine also does that but only in drive or reverse. On a cold start it'll idle at 1250, sometimes going up to 1500, and then drop down to 700-900 rpm (all that while in park).
Farino81
Jul 26, 2017 06:09 AM
mk4r34
Apr 4, 2014 09:26 AM
94LexES
Dec 20, 2013 07:50 PM
mgw234
Apr 24, 2013 09:06 PM
madmax98
Jul 13, 2008 05:39 PM
