temp gauge issue
Old Apr 14, 2013 | 11:29 AM
mgw234's Avatar
mgw234
Default temp gauge issue
Ok so I have a 1992 Lexus SC400, v8 , 183,000 miles on it.
problem i have is that when I start my car the temperature does not move at all, the needle is stuck at C. do any of you know the solution to this? thanks
Old Apr 14, 2013 | 12:11 PM
eknine9's Avatar
eknine9
Your engine thermostat could be stuck open. Or your engine temp sensor could be broken.
I'm leaning more towards engine temp sensor being broken, when the thermostat is stuck open the car will still get up in temperature a bit, just never quite to operating temp.
Old Apr 14, 2013 | 12:48 PM
mgw234's Avatar
mgw234
ok i will look into the sensor. thank you.
Old Apr 14, 2013 | 02:22 PM
Bankswood's Avatar
Bankswood
Recently had the same problem. Changed temp sensor but no change. Bought a new thermostat and everything is good now. Hint: If the temp gauge does move then it's probably the thermostat.
Old Apr 16, 2013 | 08:31 AM
mgw234's Avatar
mgw234
Ok, so i bought a new temperature sensor. When i Was ready to put it on I noticed that the connection to my old sensor was cut. (The wire itself.) So I soldered the wire together now it works. It goes up slowly now.
Thank you for the help.
Old Apr 16, 2013 | 12:50 PM
Bankswood's Avatar
Bankswood
How slowly does it go up? You should be at full running temp with in 2 miles of driving.
Old Apr 16, 2013 | 03:11 PM
mgw234's Avatar
mgw234
when it isn't driving it takes a few minutes to get past the first bar.
Old Apr 23, 2013 | 03:13 PM
mgw234's Avatar
mgw234
Also, when i turn the gears ( switching from park to drive or reverse) the car jerks forward. not the tires but the body itself.
Old Apr 23, 2013 | 03:14 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Check your motor and tranny mounts. Known problem to wear out.
Old Apr 23, 2013 | 09:10 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Rough shifts-tranny/engine mounts.
Not heating up-Thermostat
Had rough shifting problem, was tranny mounts. Have the temp not exceeding much over C, it's the thermo.
GL.
Old Apr 24, 2013 | 08:31 PM
mgw234's Avatar
mgw234
GL.
what do you recommend?
Old Apr 24, 2013 | 09:06 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Usually if you're just looking for regular/DD tranny mounts, MTC is fine. They're the cheapest as well.
As for the thermo, I just use AutoZone. Cheapskate, we all try to be.
nicky4318
Dec 16, 2017 06:53 PM
Johngoped
Oct 13, 2012 03:40 PM
pero
GS - 1st Gen (1993-1997)
Jun 1, 2009 01:40 AM
juventus20
Jun 21, 2006 05:20 AM
