Rough idle, poor driveability! Please help.
what turbo setup?
what injectors?
what are you using for fuel correction?
do you have any CEL codes?
do you have any gauges?
do you have a wideband?
you can't just post a loaded thread like this and say "the car is a sc300 na-t" like the na-t was a factory option or something. you have to tell us everything about the car.
also, feel free to tell us about this mechanic. he thinks that spark plugs --while having extensive mods done to a car (like you have)-- will cause a car to run so terribly that you can barely drive it, especially when it already has new spark plugs?
it could be a bad igniter, but they RARELY go out on these things, and the gauge clusters (tacho, speedo, needles, lights inside, etc.) are infamous for a premature malfunction and/or death.
i'm going to give you the benefit of the doubt here and assume that you all drained the 3 year old gasoline out of the tank before trying to troubleshoot this thing further...
when you first start your car, the ECU richens the fuel mixture up considerably (5-20%, maybe more depending on how cold it is outside). so while your engine is running rich, it's running smoothly. after the engine warms up to "operating temp," the ecu leans the mixture out to where it's supposed to be. this is called cold start enrichment. all stock ECUs do this.
if you drained the gas (again, i'm assuming you did) then just fill us in with some more useful information and we can try to get it figured out. if you didn't, tell your mechanic to take up a new profession, then head to the gas station.
Car is a 1993 OBD1
It uses a Toyomoto setup with a Greddy TD06-20G turbo, 2.5mm HG
Stock injectors with 2 additional 550cc injectors
Sard FPR installed
Greddy Profec EBC
Stock ECU
Haltech AIC for the 550's at boost
No CEL codes whatsoever
No fuel correction due to stock injectors
Only EGT, Boost gauge, and useless Narrowband
Just bought a wideband but still has to be installed
The turbo was completely rebuilt due to worn seals. This was the initial reason why the unit was stored for some time All replaceable parts were changed except housing and shaft/impeller (upon rebuild and install, the unit was leaking a bit of oil until the seals completely seated.) I replaced the plugs to new Denso IK20's at that point.
Yes, Gas tank was thoroughly cleaned (as in brought down) before even working on the engine, fuel drained and new walbro 255lph fuel pump installed and new fuel filter down the line.
The car doesn't sound like it is lean when it starts to act up. It sounds like it's only working on 5 cylinders and there is a smell of unburnt fuel at the exhaust but it is not smoking excessively at idle or low rpms. The exhaust tips seem wet but I don't know if that's just moisture or gas.
As mentioned, the igniter, coil, cap, rotor, wires, and plugs have been replaced. The only thing I'm considering now is that maybe one or two injectors are dirty and are not firing well. Maybe I should take them out to have them cleaned. Is this adviseable?
Please let me know if I may be missing any more info. Thank you!!!
sounds like an electrical issue. Did this cluster work previously?
I would definitely inspect the rotor, make sure the edge is not worn at all and smooth. If you have anythin but a toyota rotor and cap rip it out and get the oem stuff, I had an aftermarket rotor and cap fail on me pretty fast once, i was definately running on 2-4 cylinders when it happened.
was the distributor removed when all the maintenance was done? if so check the base timing by jumping the diagnostic terminal, and make sure it is close to spec i think 10 degrees.
you can also manually turn the motor over to TDC, remove the cap on the distributor and verify that the rotor is pointing directly at the cam sensor inside. If it is not, then it was not reinserted properly, and it should be corrected.
If all of that checks out, I would try and swap the ecu. there was another similar thread on here where the car was running badly (missing) and the car would not throw any CEL's. Turns out the ecu was bad, cause generally if you are misfiring you should be tripping some code of wether it is too rich, too lean, or random misfire code.
So I would do a check and put the key in the ignition, turn it 1 click (engine off), and see if your cel light even comes on. If it doesn't it could be a sign of a faulty ecu.
the tach acting wierd does not automatically mean the ignitor is bad, although it could be. when the coil fires off the pulse it generates is used to generate a return signal IGF in the ignitor and is also used to drive the tachometer (internally in the ignitor). If there is a no spark condition, the ignitor will not see the pulse and will know there was a misfire, so it will not send IGF or Tach signal, which in thoery cold cause the tach to act up, but the kicker is when the ecu does not get a return IGF from the ignitor it will shut off the injectors, and since your motor is still running, misifiring, and dumping fuel, all your spark events are still occurring, or your ecu simply does not care cause its fried. My first guesses would be they are firing at the wrong time, or you have a bad ecu.
In fact the thread with the bad ecu would also only occur when the car got warmed up, turned out the area next to the ecu got very wet from a bad weather sealing. something about it heating up would cause it to go crazy, but would work when cold. its worth a quick inspection of the ecu.
https://www.clublexus.com/forums/per...-92-sc400.html
no problem, yes cap and rotor would show up when cold so its probably alright. There is only one way the rotor can screw on, i dont think you can install it backwards, there is a notch. Same with the cap if you have the OEM cap. If you swapped out to a 4runner cap to better clear the turbo the wire #'s are different, but you said you have the oem one still, so not an issue.
The timing wouldn't go out from replacing the rotor and cap, only if the whole distributor was moved, like the base or pulled out. If just the cap and rotor then timing should be fine as well.
have you tried resetting the ecu, that seems to be the problem with alot of people running on the stock ecu lately. what it learnt 3 years ago may not be good anymore, may need to clear out the settings. when you first start up the car you are in open loop with no adjustments, and once it warms up its using whatever adjustments were stored previously. anytime you make a modification or tune up on the stock ecu I always give it a full reset. If you had the wideband installed it may be easier to diagnose. sometimes the stock ecu can freak out and want to idle as lean as 16:1. after a reset everything would go back to normal. i would do this every other week or so to keep everything running consistent.
I checked my timing with a timing light gun and it's like 20 Deg BTDC!! Wow...it's in total limp mode at the moment. Your's probably is too.
I'd definitely bypass that fuel ecu as stated above, and if that's not it. Check the timing for sure.
Can you guys please tell me what the ideal compression numbers should be for the 2jz-ge motor so I can be guided accordingly? Thanks! I was also deliberating on installing the 460cc injectors that are all clean and ready for install since my LS400 MAF and SAFC2 unit are waiting in the wings but my gut feel is to first find out if the original injectors are indeed the only problem before I add a new variable to the equation. Installing the new injectors would eliminate the need to get the old injectors removed, cleaned, reinstalled again only to have them removed shortly afterwards. It's just that I want to be sure everything on the baseline is working fine first so I have some peace of mind but if you guys think this is an unnecessary step, i'd like to hear from you. Thanks a bunch! I'll keep you posted on the progress.
