Idle issue.
Old May 17, 2011 | 09:28 PM
lex1220's Avatar
lex1220
Default Idle issue.
So last week I took off my IACV and cleaned it, put it back on and now the car doesn't seem to be controlling the idle by itself at all, after I hold the gas a bit to get the rpm's up I can put it in gear drive for a bit and after its warmed up it will idle at about 700 but as far as a cold start goes nope it idles at about 200 then dies. It seems like the IACV isnt working at all. Any ideas? I would be fine with just buying a new IACV if it wasn't a $260 part. Anyone know how to tell if its functioning or not? any circuit info?
Old May 17, 2011 | 09:56 PM
lex1220's Avatar
lex1220
92 sc300 auto.
Old May 18, 2011 | 07:19 AM
good2go's Avatar
good2go
It's just a stepper motor. There's a procedure in the FSM to apply power and ground to various pins in a particular order to "step" the motor and clock the valve open and closed again. I have seen it posted here before, so it should turn up with a search.
Old May 18, 2011 | 11:33 AM
lex1220's Avatar
lex1220
Makes, sense ill do a search.
Old May 18, 2011 | 01:12 PM
TechGreek's Avatar
TechGreek
Take it off the TB, leave the connector plugged in. Lay it on top of the TB to where you can see it. (if you're by your self, or have someone else play with the key).
You SHOULD see the plunger FULLY retract or extend (can't remember) I believe when you try to start it because of the huge vacuum leak then when you turn the key off and pull it out of the ignition, you should see it head the other way.
I tested the ground method, it barely moves so it's not an indicator to me to test properly.
Old May 19, 2011 | 05:17 AM
lex1220's Avatar
lex1220
Hmm ill try it. Thanks. Ill make a post as soon as I have time to do that.
b2p1986
Sep 27, 2012 10:48 AM
Sup2jzgte
Mar 19, 2012 09:33 AM
socal72
Dec 1, 2010 10:27 AM
1slowsc
Nov 5, 2010 07:56 PM
SCotty P
Sep 18, 2008 02:51 PM
